    How to change the path of a picture in magicmirror , using MMM-imageSlideshow
    17 Posts 2 Posters 5.9k Views 2 Watching
    • E Offline
      emrhssla @sdetweil
      There’s no other way.
      Then there’s one more question. Originally, MMM-Testpython is a module that uses python files to capture pictures.
      I tried to show the captured pictures using MMM-imageSlideshow.
      To sum up, what I want is:
      1.Run the magic mirror.
      2.MMM-imageSlideShow runs to show the pictures in the folder
      3.Use MMM-Testpython to capture it with a webcam.
      4.Replace original photos by covering them.
      ------I’ve been successful so far----
      5. MMM-imageSlideshow module has been updated to show only captured pictures (failed)
      So what I’m wondering is if I can update MMM-imageSlideshow in the Magic Mirror.
      Updatedom() will not be renewed.
        sdetweil @emrhssla
        @emrhssla what do u mean by update ImageSlideshow?
        Change it’s paths dynamically?
        I dont think so
        • E Offline
          emrhssla @sdetweil
          not about path update
          about replacing a picture with an overwritten one dynamically.
            sdetweil @emrhssla
            @emrhssla should be able to without problem… either write code to do it… or launch a shell cp command (copy)
              also, MMM-ImageSlideshow only gets the file list once… then reshows it over and over…
              MMM-ImagesPhotos refreshes the list every 60 seconds… ( getInterval: 60000)
              • E Offline
                emrhssla
                MMM-Testpython.js
                var Testpythons;
                Module.register("MMM-Testpython", {
                    defaults: {},
                    start: function (){
                        Testpythons = this;
                  getDom: function() {
                    var element = document.createElement("div")
                    element.className = "myContent"
                    element.id="divid"
                    element.innerHTML = "Hello, World!!! " + this.config.foo
                    var subElement = document.createElement("p")
                    subElement.innerHTML = "Click"
                    subElement.id = "clickid"
                    element.appendChild(subElement)
                    return element
                    switch(notification) {
                      case "DOM_OBJECTS_CREATED":
                      var elem = document.getElementById("clickid")
                      elem.addEventListener("click", () => {
                        Testpythons.sendSocketNotification("TEST")
                        console.log(" click success !")
                        elem.innerHTML = "click success"
                        break
                      case "AFTERCLICK":
                        console.log("Socket recevied payload : "+payload)
                        var elemk = document.getElementById("clickid")
                        Testpythons.sendNotification('SHOWCHANGEDIMAGE');
                        elemk.innerHTML = payload
                        break
                node_helper.js(in MMM-Testpython)
                var NodeHelper = require("node_helper");
                var {PythonShell} = require('python-shell');
                var socketTestpython;
                  start: function() {
                    socketTestpython=this;
                    console.log(this.name+"node_helper started")
                      case "TEST":
                        console.log("notification : " + notification)
                	    PythonShell.run('/home/pi/Desktop/BeautyMirror/modules/MMM-Testpython/before.py', null, function (err, result) {
                            if (err) throw err;
                            console.log(result);
                            socketTestpython.sendSocketNotification("AFTERCLICK",result);
                        break
                MMM-ImageSlideshow.js
                I added only the following code from the original module code.
                notificationReceived: function(notification, payload) {
                		Log.info(this.name + " - received notification: " + notification);
                		if(notification === "DOM_OBJECTS_CREATED"){
                			this.hide()
                		if(notification === "SHOWCHANGEDIMAGE"){
                			var self = this;
                			self.updateDom();
                			self.show();
                console is success…
                image before capture
                capture image
                after caputure
                • E Offline
                  emrhssla @emrhssla
                  not changed in screen omg…
                    sdetweil @emrhssla
                    @emrhssla if u stop mirror and restart, does the new image appear? (as u overlaid the old one)…
                    if not, then your overlay function doesn’t work…
                      and another test, open a browser on mm, then use the full file url to the new image file
                      file:///home/pi/MagicMirror/modules/MMM-ImageSlideshow/…
                      and see if the pic opens
                      • E Offline
                        emrhssla @sdetweil
                        Clicking makes the capture and overwrite the file successful in the process where the magic mirror is run. But it doesn’t appear on the screen.
                        When the magic mirror is turned off and restarted, a new image will appear successfully.
                        I think the code is working properly, but the MMM-imageSlideshow module is not being renewed.
