    How to change the path of a picture in magicmirror , using MMM-imageSlideshow
    17 Posts 2 Posters 6.1k Views 2 Watching
    • E Offline
      emrhssla
      I’m using three modules.
      MMM-Testpython (This is the module I’m developing.)
      MMM-imageSlideshow
      MMM-Modulebar1
      When I click the click button implemented in the Testpython module code, I want to change the path of the file where the picture is stored. So I want to show you a picture of a different path.
      modules/MMM-Testpython/nothing ->modules/MMM-Testpython/before
      I implemented it using “sendnotification” in MMM-Testpython, “notificationreceived” in MMM-imageSlideshow.
      It was confirmed that the output was successful on the console window.
      before click
      after click
      However, the picture does not change on screen.
      The code is as follows.
      MMM-imageSlideshow
      I’ve just modified the underline for @@@@@@@@@@@@@@@
      /* global Module */
      /* MMM-ImageSlideshow.js
       * Magic Mirror
       * Module: MMM-ImageSlideshow
       * Magic Mirror By Michael Teeuw http://michaelteeuw.nl
       * MIT Licensed.
       * Module MMM-ImageSlideshow By Adam Moses http://adammoses.com
       * MIT Licensed.
      Module.register("MMM-ImageSlideshow", {
      	// Default module config.
      	defaults: {
              // an array of strings, each is a path to a directory with images
              imagePaths: [ 'modules/MMM-Testpython/nothing' ],
              // the speed at which to switch between images, in milliseconds
      		slideshowSpeed: 10 * 1000,
              // if zero do nothing, otherwise set width to a pixel value
              fixedImageWidth: 0,
              // if zero do nothing, otherwise set height to a pixel value
              fixedImageHeight: 0,
              // if true randomize image order, otherwise do alphabetical
              randomizeImageOrder: false,
              // if true combine all images in all the paths
              // if false each path with be viewed seperately in the order listed
              treatAllPathsAsOne: false,
              // if true, all images will be made grayscale, otherwise as they are
              makeImagesGrayscale: false,
              // list of valid file extensions, seperated by commas
              validImageFileExtensions: 'bmp,jpg,gif,png',
      		// a delay timer after all images have been shown, to wait to restart (in ms)
      		delayUntilRestart: 0,
          // load function
      	start: function () {
              // add identifier to the config
              this.config.identifier = this.identifier;
              // ensure file extensions are lower case
              this.config.validImageFileExtensions = this.config.validImageFileExtensions.toLowerCase();
              // set no error
      		this.errorMessage = null;
              if (this.config.imagePaths.length == 0) {
                  this.errorMessage = "MMM-ImageSlideshow: Missing required parameter."
              else {
                  // create an empty image list
                  this.imageList = [];
                  // set beginning image index to -1, as it will auto increment on start
                  this.imageIndex = -1;
                  // ask helper function to get the image list
                  this.sendSocketNotification('IMAGESLIDESHOW_REGISTER_CONFIG', this.config);
      			// do one update time to clear the html
      			this.updateDom();
      			// set a blank timer
      			this.interval = null;
      	// Define required scripts.
      	getStyles: function() {
              // the css contains the make grayscale code
      		return ["imageslideshow.css"];
      	// the socket handler
      		// if an update was received
      		if (notification === "IMAGESLIDESHOW_FILELIST") {
      			// check this is for this module based on the woeid
      			if (payload.identifier === this.identifier)
      				// set the image list
      				this.imageList = payload.imageList;
                      // if image list actually contains images
                      // set loaded flag to true and update dom
                      if (this.imageList.length > 0) {
                          this.loaded = true;
                          this.updateDom();
      					// set the timer schedule to the slideshow speed
      					var self = this;
      					this.interval = setInterval(function() {
      						self.updateDom();
      						}, this.config.slideshowSpeed);
      	// Override dom generator.
      	getDom: function () {
              // if an error, say so (currently no errors can occur)
              if (this.errorMessage != null) {
                  wrapper.innerHTML = this.errorMessage;
              // if no errors
              else {
                  // if the image list has been loaded
                  if (this.loaded === true) {
      				// if was delayed until restart, reset index reset timer
      				if (this.imageIndex == -2) {
      					clearInterval(this.interval);
      					var self = this;
      						self.updateDom(0);
                      // iterate the image list index
                      this.imageIndex += 1;
      				// set flag to show stuff
      				var showSomething = true;
                      // if exceeded the size of the list, go back to zero
                      if (this.imageIndex == this.imageList.length) {
      					// if delay after last image, set to wait
      					if (this.config.delayUntilRestart > 0) {
      						this.imageIndex = -2;
      						wrapper.innerHTML = " ";
      						showSomething = false;
      						var self = this;
      							self.updateDom(0);
      							}, this.config.delayUntilRestart);
      					// if not reset index
      					else
      						this.imageIndex = 0;
      				if (showSomething) {
      					// create the image dom bit
      					var image = document.createElement("img");
      					// if set to make grayscale, flag the class set in the .css file
      					if (this.config.makeImagesGrayscale)
      						image.className = "desaturate";
      					// create an empty string
      					var styleString = '';
      					// if width or height or non-zero, add them to the style string
      					if (this.config.fixedImageWidth != 0)
      						styleString += 'width:' + this.config.fixedImageWidth + 'px;';
      					if (this.config.fixedImageHeight != 0)
      						styleString += 'height:' + this.config.fixedImageHeight + 'px;';
      					// if style string has antyhing, set it
      					if (styleString != '')
      						image.style = styleString;
      					// set the image location
      					image.src = this.imageList[this.imageIndex];
      					// ad the image to the dom
      					wrapper.appendChild(image);
                  else {
                      // if no data loaded yet, empty html
              // return the dom
      		return wrapper;
      	// @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ my code @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
      	notificationReceived: function(notification, payload) {
      		Log.info(this.name + " - received notification: " + notification);
      		if(notification === "BEFORE"){
      			console.log("this payload : "+payload)
      			this.config.imagePaths=payload
      			var self = this;
      			self.updateDom();
      			console.log("this config config payload : "+this.config.imagePaths)
      MMM-Testpython
      var Testpythons;
      Module.register("MMM-Testpython", {
          defaults: {},
          start: function (){
              Testpythons = this;
        getDom: function() {
          var element = document.createElement("div")
          element.className = "myContent"
          element.id="divid"
          element.innerHTML = "Hello, World!!! " + this.config.foo
          var subElement = document.createElement("p")
          subElement.innerHTML = "Click"
          subElement.id = "clickid"
          element.appendChild(subElement)
          return element
          switch(notification) {
            case "DOM_OBJECTS_CREATED":
            var elem = document.getElementById("clickid")
            elem.addEventListener("click", () => {
              // send!!
              Testpythons.sendNotification('BEFORE','modules/MMM-Testpython/before');
              elem.innerHTML = "click success"
              break
        sdetweil @emrhssla
        @emrhssla i think this is a caching problem… the ‘file’ was already loaded…
        see this discussion about adding a string to the end of the image filename to make it ‘unique’
        thus not reading from cache
        https://stackoverflow.com/questions/728616/disable-cache-for-some-images
        however, this will add a new image to be cached… eventually growing maybe beyond memory limits…
        another way is to disable caching in electron
        in MagicMirror/js/electron.js
        add this line
        function createWindow() {
            app.commandLine.appendSwitch('--disable-http-cache');  //< -------- added
        	var electronOptionsDefaults = {
          sdetweil @emrhssla
          @emrhssla because ImageSlideshow is using hard coded paths
          imagePaths: [ ‘modules/MMM-Testpython/nothing’ ],
          U must add the before path to the list
          • E Offline
            emrhssla @sdetweil
            There’s no other way.
            Then there’s one more question. Originally, MMM-Testpython is a module that uses python files to capture pictures.
            I tried to show the captured pictures using MMM-imageSlideshow.
            To sum up, what I want is:
            1.Run the magic mirror.
            2.MMM-imageSlideShow runs to show the pictures in the folder
            3.Use MMM-Testpython to capture it with a webcam.
            4.Replace original photos by covering them.
            ------I’ve been successful so far----
            5. MMM-imageSlideshow module has been updated to show only captured pictures (failed)
            So what I’m wondering is if I can update MMM-imageSlideshow in the Magic Mirror.
            Updatedom() will not be renewed.
              sdetweil @emrhssla
              @emrhssla what do u mean by update ImageSlideshow?
              Change it’s paths dynamically?
              I dont think so
              • E Offline
                emrhssla @sdetweil
                not about path update
                about replacing a picture with an overwritten one dynamically.
                  sdetweil @emrhssla
                  @emrhssla should be able to without problem… either write code to do it… or launch a shell cp command (copy)
                    also, MMM-ImageSlideshow only gets the file list once… then reshows it over and over…
                    MMM-ImagesPhotos refreshes the list every 60 seconds… ( getInterval: 60000)
                    • E Offline
                      emrhssla
                      MMM-Testpython.js
                      var Testpythons;
                          defaults: {},
                          start: function (){
                              Testpythons = this;
                          element.id="divid"
                          return element
                              Testpythons.sendSocketNotification("TEST")
                              console.log(" click success !")
                              break
                            case "AFTERCLICK":
                              console.log("Socket recevied payload : "+payload)
                              var elemk = document.getElementById("clickid")
                              Testpythons.sendNotification('SHOWCHANGEDIMAGE');
                              elemk.innerHTML = payload
                              break
                      node_helper.js(in MMM-Testpython)
                      var NodeHelper = require("node_helper");
                      var {PythonShell} = require('python-shell');
                      var socketTestpython;
                        start: function() {
                          socketTestpython=this;
                          console.log(this.name+"node_helper started")
                            case "TEST":
                              console.log("notification : " + notification)
                      	    PythonShell.run('/home/pi/Desktop/BeautyMirror/modules/MMM-Testpython/before.py', null, function (err, result) {
                                  if (err) throw err;
                                  console.log(result);
                                  socketTestpython.sendSocketNotification("AFTERCLICK",result);
                              break
                      I added only the following code from the original module code.
                      		if(notification === "DOM_OBJECTS_CREATED"){
                      			this.hide()
                      		if(notification === "SHOWCHANGEDIMAGE"){
                      			var self = this;
                      			self.updateDom();
                      			self.show();
                      console is success…
                      image before capture
                      capture image
                      after caputure
                      • E Offline
                        emrhssla @emrhssla
                        not changed in screen omg…
                          sdetweil @emrhssla
                          @emrhssla if u stop mirror and restart, does the new image appear? (as u overlaid the old one)…
                          if not, then your overlay function doesn’t work…
