    multiple carousals not rendering as expected
    magic mirrorslidetroubleshoothelpfix
    5 Posts 2 Posters 2.5k Views 2 Watching
      sunnykeerthi
      I’m creating 2 carousals one on top_center and another in bottom_bar. Both of them are working perfectly when I run them separately(by commenting out either top or bottom part in config.js). when I run them together they seem to show up in random times, though the interval set is the same. Here is my code.
      my first slide page
      Module.register("deImages", {
      	// Default module config.
      	defaults: {
      		width: 200,
      		height: 200,
      		text: "Hello World!",
      		slideIndex: -1,
      		rotateInterval: 30 * 1000,
      		animationSpeed: 3000, // fade in and out speed
      		initialLoadDelay: 4250,
      		retryDelay: 2500,
      		updateInterval: 60 * 60 * 1000,
      	total_info: "Hello World!",
      	getStyles: function () {
      		return [
      			'deImagesStyle.css'
      	getDom: function () {
      		var wrapperEl = document.createElement("div");
      		var container = document.createElement("div");
      		container.className = "slideshow-container";
      		var div1 = document.createElement("div");
      		div1.className = "mySlides fade";
      		var img1 = document.createElement("img");
      		img1.src = "https://www.w3schools.com/howto/img_nature_wide.jpg";
      		div1.appendChild(img1);
      		container.appendChild(div1);
      		var div2 = document.createElement("div");
      		div2.className = "mySlides fade";
      		var img2 = document.createElement("img");
      		img2.src = "https://www.w3schools.com/howto/img_mountains_wide.jpg";
      		div2.appendChild(img2);
      		container.appendChild(div2);
      		var div3 = document.createElement("div");
      		div3.className = "mySlides fade";
      		var img3 = document.createElement("img");
      		img3.src = "https://www.w3schools.com/howto/img_snow_wide.jpg";
      		div3.appendChild(img3);
      		container.appendChild(div3);
      		wrapperEl.appendChild(container);
      		Log.log("slide payload >> ");
      		return wrapperEl;
      	showSlides1: function () {
      		if (!this.slideIndex) {
      			this.slideIndex = 0;
      		var i;
      		var slides = document.getElementsByClassName("mySlides");
      		for (i = 0; i < slides.length; i++) {
      			console.log(slides[i]);
      			slides[i].style.display = "none";
      		this.slideIndex++;
      		slides[this.slideIndex - 1].style.display = "block";
      		if (this.slideIndex > (slides.length - 1)) { this.slideIndex = 0 }
      		setInterval(this.showSlides1, 2000);
      	start: function () {
      		this.sendSocketNotification('duDash_initConnection');
      	socketNotificationReceived: function (notification, payload) {
      		if (notification === "duDash_updateNumbers") {
      			Log.log("payload >> " + payload);
      			this.total_info = payload;
      			this.updateDom();
      and here is my 2nd file
      Module.register("deImages_2", {
      	defaults: {
      		width: 200,
      		height: 200,
      		slideIndex: -1,
      		retryDelay: 2500,
      		return [
      			'deImagesStyle2.css'
      		return wrapperEl;
      	showSlides2: function () {
      		var i;
      		this.slideIndex++;
      		setInterval(this.showSlides2, 2000);
      		this.sendSocketNotification('duDash_initConnection2');
      		if (notification === "duDash_updateNumbers2") {
      			this.updateDom();
      when I run this, Here is a small gif that I’ve recorded to show the output.
      https://giphy.com/gifs/XbD0g7cAz8zVdwtQLj/fullscreen
      please let me know where am I going wrong and how Can I run the two files parallel instead of simultaneously.
      Thanks,
      Sunny
        sdetweil
        At the end if your showslides functions add
        this.updateDom(1000)
        To tell mm to get the new content via the getDom() function
          sunnykeerthi
          Hi @sdetweil ,
          thanks very much for the quick reply. I added this.updateDom(1000), but I get the error as below.
          Uncaught TypeError: this.updateDom is not a function
          I did the below to both my files.
          this.slideIndex++;
            this.slideIndex = 0
          this.updateDom(1000);
          please let me know where am I going wrong.
            sdetweil @sunnykeerthi
            @sunnykeerthi weird
            U used it above
            this.updateDom()
              actually this is because you have fired a timer on the slide update
              		var i;
              		this.slideIndex++;
              		setInterval(this.showSlides2, 2000);   //< ------- here restarts the function, BUT inside the function  'this'; becomes the context of the timer routine and not the module..
                              this.updateDom(1000);  // or whatever transition time u want.
              to fix it you need an arrow function to keep context right
              see https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Functions/Arrow_functions
              but net
              		var i;
              		this.slideIndex++;
              		setInterval( () => { this.showSlides2()} , 2000);   // < --- was a typo here..  need () => { stuff }
