    how to divide the payload of socketnotification
    4 Posts 2 Posters 1.1k Views 2 Watching
    • C Offline
      cycaaa
      I have this problem. The code below sends an alert to Socket Notify and other modules handle the notification.
      sendNotification ‘result’
          switch(notification) {
            case "TEST":
              console.log("notification : " + notification)
      	    PythonShell.run('c://Users/user/Desktop/MagicMirror-master/modules/MMM-Testpython/FCF.py', null, function (err, result) {
                  if (err) throw err;
                  console.log("sex" + result);
                  socketTestpython.sendSocketNotification("I_DID",result);
              break
      recived notification but the ‘split’ doesn’t work.
      The log with the payload as a factor is well show. but Payload 3 is not show.
            case "I_DID":
              console.log("Socket recevied 1: " + payload);
              var payload3;
              payload3=payload.split("_");
              console.log("Socket recevied 1: " + payload3);
              var elemk = document.getElementById("showage");
              var sex = payload3[0];
              console.log("Socket recevied 1: " + sex);
              var age = payload3[1];
              console.log("Socket recevied 1: " + age);
              var change;
              if (sex == "Male"){
      Why doesn’t the split work?
        sdetweil @cycaaa
        @cycaaa can u show the payload?
        • C Offline
          cycaaa @sdetweil
          is my payload.
          0_1557182965874_캡처.PNG image url)
            sdetweil @cycaaa
            @cycaaa looks like result in node_helper is not a string object
            according to the doc, results is an array
            PythonShell.run('my_script.py', options, function (err, results) {
              if (err) throw err;
              // results is an array consisting of messages collected during execution
              console.log('results: %j', results);
            SO, you need to get them all, so, sendSocketNotification(“string”,results.join(’ '))
