    Screen Rotation Help
    3 Posts 2 Posters 1.2k Views 2 Watching
      motdog
      So I’m finally building the mirror I’m gifting next Sat and need to change display to portrait. The threads I’ve seen have been on older versions of the software. Has anything changed since the new version? What’s the easiest way to do this?
      I’m using a 3b+.
      I read something about MMM-RemoteControl being wonky if you do this. Any help for clueless dude would be awesome
        sdetweil @motdog
        @motdog see this topic
        https://forum.magicmirror.builders/topic/10404/vertical-image-diagonal-line-issue/11
          motdog @sdetweil
          @sdetweil I will. It’s a vga connection not hdmi if that matters. Since it’s a gift I don’t want to have to enter code on every reboot so worse case I have the frame turned to landscape vs portrait
