    MMM-GoogleAssistant autostart
    46 Posts 3 Posters 25.3k Views 3 Watching
    • P Offline
      poopyurinal
      pm2 stop MagicMirror gives me:
      [PM2][ERROR] Process MagicMirror not found
      │ Name │ id │ mode │ status │ ↺ │ cpu │ memory │
      │ mm │ 0 │ fork │ online │ 1 │ 0% │ 2.5 MB │
      Use pm2 show <id|name> to get more details about an app
      Any thoughts? The MagicMirror is running. If I stop it by hitting Alt and closing it via the menu bar, it automatically restarts.
        sdetweil @poopyurinal
        @poopyurinal pm2 list
        • P Offline
          poopyurinal
          pm2 list
            @poopyurinal pm2 stop mm
            • P Offline
              poopyurinal
              pm2 stop mm
              [PM2] Applying action stopProcessId on app [mm](ids: 0)
              [PM2] mm ✓
              │ mm │ 0 │ fork │ stopped │ 1 │ 0% │ 0 B │
              Sorry, limited by new user restriction of one post every 120 seconds
                @poopyurinal cool now follow the link i gave about creating a service that will autostart and make it start the assitant.py
                I don’t understand why the MMM-GoogleAssistant module doesn’t do this… it would be so easy…
                  sdetweil
                  in the link it asks for ‘your service name’ make that GoogleAssistant
                  the command is ‘/home/pi/MagicMirror/modulesMMM-GoogleAssistant/python3 assistant.py’
                    sdetweil
                    once u create the service… make sure assistant.py is not running already
                    ps -ef | grep assistant
                    the 1st number on the output is the process id
                    pi xxxx yyyy etc…
                    then
                    sudo kill -9 xxxx
                    then do
                    sudo systemctl start GoogleAssistant
                    then
                    to insure assistant is running
                    then start mirror manually with npm start
                    if all is good, reboot
                    service will start the assistant.py script
                    and pm2 will start mirror app
                    • P Offline
                      poopyurinal
                      Many thanks Sam! I’ll need to take a look at your suggestions tomorrow. I appreciate the quick (immediate!) help.
                        @poopyurinal no problem… let us know either way
                        i use the assistantmk2 module… don’t need that py file
                        • 2 / 5
