    Region/module positioning on Servermode (on docker, Synology) and client (web-browser)
    2 Posts 1 Posters 990 Views 1 Watching
      skibro
      Hi MagicMirror Builders!
      I’ve got stuck with the positioning of modules/regions. My setup:
      MagicMirror2 running in servermode in a docker container on a Synology.
      The client would be a tablet (untill I fix a monitor and a PI), I am planning to show the info board in a browser.
      Setup is finished, I am able to install/config modules, apply css. The problem is that when I open the ip of the mirror in a browser, the alignment of the regions is not ok. It seems like the _left and _right regions are just on top each other. I tried to modify the “body” in the custom.css, it works (the modules become wider), but the alignment is the same, I can not place the top_left and top_right regions nex to each other.
      I have no experience in css or js, but tried to find a solution on the forum, without luck. Can you please point me in the right direction? How could I set the window size for the MM?
      My modules config:
      			module: "clock",
      			position: "top_right"
      			module: "currentweather",
      				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
      				appid: ""
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "",  //ID from https://openweathermap.org/city
      				appid: ""
      Thanks in advance!
      Balint
        skibro
        A short update: I was able to move the modules manually using css. It seems to work but it’s not an elegant solution. Any ideas/suggestions how to do it right?
        tml {
        	height: 1080px;
        	width: 1920px;
        header {
        	text-transform: uppercase;
        	font-size: 26px;
        	font-family: "Roboto Condensed";
        	font-weight: 600;
        	border-bottom: 1px solid white;
        	line-height: 15px;
        	padding-bottom: 5px;
        	margin-bottom: 10px;
        	color: cadetblue;
        body {
        	margin: 10px;
        	position: absolute;
        	height: 1080;
        	width: 1920px;
        	background-color: rgba(214, 214, 214, 0.8);
        	background-repeat: no-repeat;
        	/*background-size: 1920;*/
        	font-family: "Roboto Condensed", sans-serif;
        	font-weight: 400;
        	font-size: 2em;
        	line-height: 1.5em;
        	-webkit-font-smoothing: antialiased;
        .region.top.left .container .module.currentweather {
        width: 400px;
        height: 250px;
        position: absolute;
        left: 90px;
        top: 90px;
        background-color: rgba(20, 102, 186, 0.5); /*kek*/
        .module.clock {
        width: 400px;
        height: 400px;
        position: absolute;
        left: 760px;
        top: 90px;
        background-color: rgba(80, 196, 0, 0.5); /*zold*/
        .region.top.right .container .module.MMM-SL-PublicTransport {
        width: 400px;
        height: 500px;
        position: absolute;
        left: 1490px;
        top: -00px;
        .region.bottom.bar .container {
        width: 1740px;
        height: 310px;
        position: absolute;
        left: 90px;
        top: 680px;
        background-color: rgba(247, 173, 236, 0.5); /*magente*/
