api info to table
6 Posts 2 Posters 2.3k Views 2 Watching
  • E Offline
    epi
    Can someone make a simple mm module?
    Get data from any of those api https://github.com/opendata-stuttgart/meta/wiki/APIs and make a table out of them?
    Only 4 parameters needs to be fetched & displayed: PM2.5, PM10, temperature, humidity
    S 1 Reply Last reply May 18, 2019, 12:59 PM Reply Quote 0
      sdetweil @epi
      @epi see https://github.com/timdows/MMM-JsonTable
      • E Offline
        epi
        can I ask for help?
        i did install everything, but i’m seeing errors for “json data is not of type array”
        can you help me with exact url (https://docs.opensensemap.org/)?
        S 1 Reply Last reply May 18, 2019, 1:49 PM Reply Quote 0
          sdetweil @epi
          @epi in the original link, the apis listed below “Accessing the API data:” show returning an array of values
          • E Offline
            epi
            @sdetweil still get the same error. here is the url
            https://api.opensensemap.org/boxes/57000b8745fd40c8196ad04c
            E 1 Reply Last reply May 18, 2019, 2:25 PM Reply Quote 0
            • E Offline
              epi @epi
              ok, found the issue, needed to define arrayName. Thanks!
