    MMM-google-route and coordinates
    7 Posts 2 Posters 2.3k Views 2 Watching
    • Z Offline
      Zippyczech
      Hey guys,
      I´m working on my MM, and I found module MMM-google-route which I want to use for showing the route from my home to my work, but I´m not able to set the coordinates from google.maps.DirectionsRequest interface because of my lack of skills :) Any help would be welcomed.
      Btw, for anyone who want to use the module, there is mistake on github example, its missing , at end of the exaple, its should be
                  module: 'MMM-google-route',
                  position: 'top_left',
                      key: '<YOUR_KEY>',
                      directionsRequest:{
                          origin: '<ROUTE START>',
                          destination: '<ROUTE FINISH>'
      code_text
        sdetweil @Zippyczech
        @Zippyczech use the latitude/longitude…
        open google maps, find the location
        in the address bar/location
        for New York, Ny, USA
        maps/place/New+York,+NY/@40.6971478,-74.2605536,
        the 2 numbers are the latitude (above/below equator), and longitude (east/west of London, approx)
        use one set for origin and one for destination
        • Z Offline
          Zippyczech
          I´m retarded, of course, it worked. I tried the first time and did some mistake so it didnt work.
          Thank you
          Btw, do you know how to specify that the route should use subway only?
            @Zippyczech sorry. Don’t know anything about the module
              sdetweil
              Looking at the code, it appears u could change the code to support train
              travelMode: 'DRIVING'
              But not thru config altho that would be an easy change I think.
              • Z Offline
                Zippyczech
                Thank you, again, solved it moments later :) I used https://github.com/jclarke0000/MMM-MyCommute which has better configuration options
                  @Zippyczech cool. Thanks for providing feedback.
