    Finding module classes
    11 Posts 3 Posters 6.2k Views 2 Watching
      jakuk
      Hi there, I’m trying to change the colour of different modules, can anyone tell me how to find the different classes within a module for example, I’ve changed the newsfeed to yellow the topics are shown in yellow but the “BBC 12 yours ago” is still in white, so how do I find out what the class is called?
      Thanks in advance.
      Jack
        sdetweil @jakuk
        @jakuk welcome to the fun…
        each module can have its own…
        in MagicMirror/css/main.css or custom.css, or in the module folder ???.css
        you should find their classes, prefixed with the .(dot)modulename
        now, finding where its used is either
        1. in the module config
        2. in the module code. (usually module_name.js)…
          this is tedious, finding each place where the class= or style= uses some value.
        BBC 12 hours ago is an RSS feed I guess, so the rss/newsfeed module
        when the modules are provided by MM, they are in the modules/defaults folder
          broberg Project Sponsor
          the classes can be found either by checking the “inspector” with your browser or in the modules .js-file
          the “12 hours ago” uses the class “dimmed” that decides the color of that section.
          So
          .newsfeed .dimmed {color: yellow}
            jakuk
            Thank you for your reply’s, yes when going into the .js folders I search for class, and then work through all the classes to see which ones I want… so thank you for your help… I’m stuck on the calendar module… I have changed the symbol, time, title of the reminder, all works fine, my problem is I can’t seem to find the class for the actually calendar name I renamed it family calendar. Can you help with his please…
              sdetweil @jakuk
              @jakuk looking at the code, there are config options for each calendar url
              the title is
              	titleClassForUrl: function (url) {
              		return this.getCalendarProperty(url, "titleClass", "");
                jakuk @sdetweil
                @sdetweil yes I found that too but putting this code in my custom.css file won’t change the follow of the name of the calendar? Am I doing it wrong?
                Thanks again
                .calendar .titleClass {
                Color: yellow
                  sdetweil @jakuk
                  @jakuk AND in addition, it goes in the config file where u defined your calendar entry
                              symbol: "family ",
                             url: "webcal://c....",
                             titleClass:   class_name
                             ... and there are other classes for each part...
                  and color is lowercase
                    broberg Project Sponsor @sdetweil
                    @sdetweil said in Finding module classes:
                    It’s good practice, but css doesn’t care about upper/lowercase
                      jakuk
                      Sorry i’m really confused now, in my config file i have this. I don’t have a titleClass, i have named the calendar under the header?
                      Do i just need to put color under the config ?
                            module: 'calendar',
                            header: 'Family Calendar',
                            position: 'top_left',
                            fetchInterval: '30000',
                                  symbol: 'calendar-check-o',
                                  url: ********
                              titleReplace: {
                                'De verjaardag van ': '',
                                '\'s birthday': ''
                              excludedEvents: []
                        sdetweil @jakuk
                        @jakuk you need to do two things, for each change
                        1. add a css entry to specifically identify the behavior
                        2. tell the calendar module to use your class
                          so, inside the calendar entry add the titleClass: class_name (step 1)
                          to the config (with appropriate commas etc)
                        you do NOT have to change the original class (if one is used, in case of title, none is specified)
                          sdetweil
                          see the calendar module readme
                          https://github.com/MichMich/MagicMirror/blob/master/modules/default/calendar/README.md#calendar-configuration-options
