    node serveronly not working
    6 Posts 4 Posters 5.2k Views 4 Watching
      Jeff
      I try to reach my MM on serveronly mode.
      The command says : Ready to go! Please point your browser to: http://localhost:8080
      But when I go to http://localhost:8080
      the browser says: Not reachable
      ("Diese Website ist nicht erreichbar
      localhost hat die Verbindung abgelehnt.")
      What do I have to do?
      • strawberry 3.141S Offline
        localhost will only work if you’re trying to access the site on the raspberry itself, on a diferent device you have to replace localhost with the ip of the raspberry
          Jeff @strawberry 3.141
          @strawberry-3.141 said in node serveronly not working:
          I was on the raspi
          morozgrafixM 1 Reply Last reply Reply Quote 0
          • C Offline
            creye
            Did you change the ip whitelist?
              strawberry 3.141 Project Sponsor Module Developer @creye
              @creye this feature is just available since two weeks and the device the magicmirror is running on is allowed by default
              • morozgrafixM Offline
                morozgrafix Moderator @Jeff
                I realize that this topic is about 2 months old, but I’m going to add some possible troubleshooting steps for anyone who may run into this problem. Hopefully OP already has this resolved.
                @Jeff while on RasPi terminal can you try to execute this command ping localhost? you should see output similar to this:
                $ ping localhost
                PING localhost (127.0.0.1) 56(84) bytes of data.
                64 bytes from localhost (127.0.0.1): icmp_seq=1 ttl=64 time=0.253 ms
                64 bytes from localhost (127.0.0.1): icmp_seq=2 ttl=64 time=0.268 ms
                64 bytes from localhost (127.0.0.1): icmp_seq=3 ttl=64 time=0.257 ms
                as you can see hostname localhost resolves to ip address 127.0.0.1 which is very common. you can also try to enter http://127.0.0.1:8080 in your browser.
                if the above works and after node serveronly is running, can you please try to execute following command curl -I http://localhost:8080? your output should be similar to this:
                $ curl -I http://localhost:8080
                HTTP/1.1 200 OK
                X-Powered-By: Express
                Accept-Ranges: bytes
                Cache-Control: public, max-age=0
                Last-Modified: Wed, 21 Dec 2016 06:49:47 GMT
                ETag: W/"8da-15920249be6"
                Content-Type: text/html; charset=UTF-8
                Content-Length: 2266
                Date: Sun, 15 Jan 2017 23:09:37 GMT
                Connection: keep-alive
                if it’s not double check your config.js to make sure your server is running on port 8080
