    Mirror starts not correct
    18 Posts 5 Posters 7.7k Views 4 Watching
    • T Offline
      thedk
      Jusat am month ago, it starts again, but with an other fault
      0|mm  | > magicmirror@2.8.0 start /home/pi/MagicMirror
      0|mm  | > sh run-start.sh
      0|mm  | /home/pi/MagicMirror/node_modules/electron/dist/electron: relocation error: /home/pi/MagicMirror/node_modules/electron/dist/libffmpeg.so: symbol cnprantf, version GLIBC_2.4 not defined in file libc.so.6 with link time reference
      0|mm  | npm
      0|mm  |  ERR! file sh
      0|mm  | npm ERR! code ELIFECYCLE
      0|mm  | npm ERR! errno ENOENT
      0|mm  | npm ERR! syscall spawn
      0|mm  | npm
      0|mm  |  ERR! magicmirror@2.8.0 start: `sh run-start.sh`
      0|mm  | npm ERR! spawn ENOENT
      0|mm  | npm
      0|mm  |  ERR!
      0|mm  | npm ERR! Failed at the magicmirror@2.8.0 start script.
      0|mm  | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      0|mm  | npm ERR! A complete log of this run can be found in:
      0|mm  | npm ERR!     /home/pi/.npm/_logs/2019-08-12T05_54_45_996Z-debug.log
      I didnt changed anything, the error came from one day to the other an i just see the startscreen and the mirror wont start.
      Could somebody help?
      mumblebajM T 2 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        mumblebaj Module Developer @thedk
        @thedk Have you upgraded your installation of Raspbian before updating the MM? You would also have to check every module folder that has a package.json and run npm install in the module folder. This has generally worked for most of the guys with the same issue as you have.
        • T Offline
          thedk
          I didnt upgrade, i made an complete new installation cause of the issue i had before.
          Since two days the mirror has no error and everything goes fine, dont know why. I made no upgrade or similar but will do this now. Maybe the issue is gone with that.
          Thanks for your help.
            @thedk Please remember to check every module folder that has a package.json in it and run npm install in those folders as well.
            • T Offline
              thedk
              I will do this.
              Thanks.
              • T Offline
                thedk @thedk
                @thedk said in Mirror starts not correct:
                0|mm  | npm
                0|mm  |  ERR! file sh
                0|mm  | npm
                0|mm  | npm
                0|mm  |  ERR!
                About a month ago and now again…
                Everything is up to date but the issue is still there. Each day when the Mirror starts, the error comes second for second. A reboot solves the problem the mirror is runinng without problems.
                Are there people where the Mirror is working für ober two months without issues? ^^
                  sdetweil @thedk
                  sorry, I am not quite sure I am understanding…
                  you start the mirror (with pm2? or manually?), and it fails, with the above message
                  and then you reboot
                  and it runs ok…
                  and runs ok for how long?
                  i have 5 mirror instances, and all have been running for months without issues like this
                  did u put updates onto your operating system, or were some applied automatically?
                  libc.so.6 is a system library
                  • T Offline
                    thedk
                    The mirror starts every day automatically with pm2 throw a smart plug and the raspberry shuts down throw corn every day.
                    At the first start, he wont run with the log above, when i reboot the pi he is working without any problems till he shuts down at the end of the day.
                    All updates were made by me, none automatically.
