    Mirror starts not correct
    18 Posts 5 Posters 9.8k Views 4 Watching
    • Mykle1M
      @sdetweil said in Mirror starts not correct:
      one of my sd cards suddenly became read only… no fix…
      had to buy new sd card
      Sux! :-(
      • T
        thedk @Mykle1
        @Mykle1
        No i cant. I just can reboot or shutdown the Pi by Terminal.
        I know i shouldnt unplug the Pi ^^
        • T
          thedk
          Jusat am month ago, it starts again, but with an other fault
          0|mm  | > magicmirror@2.8.0 start /home/pi/MagicMirror
          0|mm  | > sh run-start.sh
          0|mm  | /home/pi/MagicMirror/node_modules/electron/dist/electron: relocation error: /home/pi/MagicMirror/node_modules/electron/dist/libffmpeg.so: symbol cnprantf, version GLIBC_2.4 not defined in file libc.so.6 with link time reference
          0|mm  | npm
          0|mm  |  ERR! file sh
          0|mm  | npm ERR! code ELIFECYCLE
          0|mm  | npm ERR! errno ENOENT
          0|mm  | npm ERR! syscall spawn
          0|mm  | npm
          0|mm  |  ERR! magicmirror@2.8.0 start: `sh run-start.sh`
          0|mm  | npm ERR! spawn ENOENT
          0|mm  | npm
          0|mm  |  ERR!
          0|mm  | npm ERR! Failed at the magicmirror@2.8.0 start script.
          0|mm  | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          0|mm  | npm ERR! A complete log of this run can be found in:
          0|mm  | npm ERR!     /home/pi/.npm/_logs/2019-08-12T05_54_45_996Z-debug.log
          I didnt changed anything, the error came from one day to the other an i just see the startscreen and the mirror wont start.
          Could somebody help?
          mumblebajM T 2 Replies Last reply
          • mumblebajM
            mumblebaj Module Developer @thedk
            @thedk Have you upgraded your installation of Raspbian before updating the MM? You would also have to check every module folder that has a package.json and run npm install in the module folder. This has generally worked for most of the guys with the same issue as you have.
            • T
              thedk
              I didnt upgrade, i made an complete new installation cause of the issue i had before.
              Since two days the mirror has no error and everything goes fine, dont know why. I made no upgrade or similar but will do this now. Maybe the issue is gone with that.
              Thanks for your help.
              mumblebajM 1 Reply Last reply
              • mumblebajM
                @thedk Please remember to check every module folder that has a package.json in it and run npm install in those folders as well.
                • T
                  thedk
                  I will do this.
                  Thanks.
                  • T
                    thedk @thedk
                    @thedk said in Mirror starts not correct:
                    0|mm  | npm
                    0|mm  |  ERR! file sh
                    0|mm  | npm
                    0|mm  | npm
                    0|mm  |  ERR!
                    About a month ago and now again…
                    Everything is up to date but the issue is still there. Each day when the Mirror starts, the error comes second for second. A reboot solves the problem the mirror is runinng without problems.
                    Are there people where the Mirror is working für ober two months without issues? ^^
                      sdetweil @thedk
                      sorry, I am not quite sure I am understanding…
                      you start the mirror (with pm2? or manually?), and it fails, with the above message
                      and then you reboot
                      and it runs ok…
                      and runs ok for how long?
                      i have 5 mirror instances, and all have been running for months without issues like this
                      did u put updates onto your operating system, or were some applied automatically?
                      libc.so.6 is a system library
                      • T
                        thedk
                        The mirror starts every day automatically with pm2 throw a smart plug and the raspberry shuts down throw corn every day.
                        At the first start, he wont run with the log above, when i reboot the pi he is working without any problems till he shuts down at the end of the day.
                        All updates were made by me, none automatically.
