    Mirror starts not correct
    18 Posts 5 Posters 9.0k Views 4 Watching
    • T Offline
      thedk
      Could somebody help with this fault?
      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
      0|mm       | Initializing new module helper ...
      0|mm       | Module helper loaded: MMM-Remote-Control
      0|mm       | Module helper loaded: MMM-Remote-Control-Repository
      0|mm       | Module helper loaded: MMM-ModuleScheduler
      0|mm       | Module helper loaded: MMM-PIR-Sensor
      0|mm       | No helper found for module: MMM-EyeCandy.
      0|mm       | Whoops! There was an uncaught exception...
      0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|mm       |     at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
      0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:551:3)
      0|mm       |     at Module.require (internal/modules/cjs/loader.js:658:17)
      0|mm       |     at require (internal/modules/cjs/helpers.js:20:18)
      0|mm       | XDG_RUNTIME_DIR (/run/user/1000) is not owned by us (uid 0), but by uid 1000! (This could e g happen if you try to connect to a non-root PulseAudio as a root user, over the native protocol. Don't do that.)
      0|mm       | TypeError: Invalid item
      0|mm       |     at Menu.insert (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:109:11)
      0|mm       |     at Menu.append (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:104:15)
      0|mm       |     at sorted.forEach (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:171:10)
      0|mm       |     at Array.forEach (<anonymous>)
      0|mm       |     at Function.Menu.buildFromTemplate (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:167:10)
      0|mm       |     at App.app.once (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:240:21)
      0|mm       |     at Object.onceWrapper (events.js:273:13)
      0|mm       |     at App.emit (events.js:187:15)
      0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
      Yesterday i made the update to 2.8.0 and now the mirror starts but i cant see it. I just see the startscreen.
      The Log doesnt make sence to me.
        bhepler Module Developer
        That’s… well, that’s a new one.
        I hate to say it, but I would recommend a reinstall of the MagicMirror framework. This isn’t pleasant but it can be accomplished in about 30 minutes.
        First step: back up your config.js file. Copy it to your /home/pi directory or wherever. Verify that it copied properly.
        Second step: write down a list of all of your installed modules.
        3rd step: Stop the magic mirror framework. Usually this is pm2 stop all.
        4th step: Delete the magic mirror folder. rm -rf /home/pi/MagicMirror
        5th re-clone Magic Mirror manually. git clone https://github.com/MichMich/MagicMirror.git
        6th step: install Magic Mirror (this will take a few minutes):
        cd /home/pi/MagicMirror
        npm install
        7th step - Install modules: Change to the modules folder: cd /home/pi/MagicMirror/modules. For each module in your config.js file, find them on GitHub and clone the module. git clone [module url]. Be sure to follow the installation instructions for each module. Some will be easy, some will involve the npm install command, and some will be complex (MMM-FitBit).
        8th Step - copy your config.js from backup to the original location in /home/pi/MagicMirror/config.
        9th step: run the MagicMirror process and see how she rolls: pm2 start MagicMirror.
          sdetweil @bhepler
          @bhepler rename the magic mirror folder. Do not delete til u are happily running again
          • T Offline
            thedk
            A reinstall wouldnt be the Problem. It is not the first time i have to do this ^^
            But i really dont unterstand why he wont start anymore. I also had this before the update, forgot to write. From one to the other the Mirror doesnt starts just with the first start of the day. When i reboot or just unplug the Pi, the mirror starts correct
              Mykle1 Project Sponsor Module Developer @thedk
              @thedk said in Mirror starts not correct:
              I hope you’re shutting down correctly before pulling the plug on the Pi. Your SD card will likely become corrupted. Just something you should think about.
              S T 2 Replies Last reply Reply Quote 0
                sdetweil @Mykle1
                @Mykle1 one of my sd cards suddenly became read only… no fix…
                had to buy new sd card
                • T Offline
                  thedk @Mykle1
                  @Mykle1
                  I just unplug the Pi sometimes since he is not starting anymore
                  I know thats not the best way, it’s my 4th Pi ;)
                    You can’t choose “Shut Down” from the desktop? Once the shut down is complete, THEN pull the plug to power down the Pi
                      @sdetweil said in Mirror starts not correct:
                      Sux! :-(
                      • T Offline
                        thedk @Mykle1
                        @Mykle1
                        No i cant. I just can reboot or shutdown the Pi by Terminal.
                        I know i shouldnt unplug the Pi ^^
                        • T Offline
                          thedk
                          Jusat am month ago, it starts again, but with an other fault
                          0|mm  | > magicmirror@2.8.0 start /home/pi/MagicMirror
                          0|mm  | > sh run-start.sh
                          0|mm  | /home/pi/MagicMirror/node_modules/electron/dist/electron: relocation error: /home/pi/MagicMirror/node_modules/electron/dist/libffmpeg.so: symbol cnprantf, version GLIBC_2.4 not defined in file libc.so.6 with link time reference
                          0|mm  | npm
                          0|mm  |  ERR! file sh
                          0|mm  | npm ERR! code ELIFECYCLE
                          0|mm  | npm ERR! errno ENOENT
                          0|mm  | npm ERR! syscall spawn
                          0|mm  | npm
                          0|mm  |  ERR! magicmirror@2.8.0 start: `sh run-start.sh`
                          0|mm  | npm ERR! spawn ENOENT
                          0|mm  | npm
                          0|mm  |  ERR!
                          0|mm  | npm ERR! Failed at the magicmirror@2.8.0 start script.
                          0|mm  | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                          0|mm  | npm ERR! A complete log of this run can be found in:
                          0|mm  | npm ERR!     /home/pi/.npm/_logs/2019-08-12T05_54_45_996Z-debug.log
                          I didnt changed anything, the error came from one day to the other an i just see the startscreen and the mirror wont start.
                          Could somebody help?
                          mumblebajM T 2 Replies Last reply Reply Quote 0
                          • mumblebajM Online
                            mumblebaj Module Developer @thedk
                            @thedk Have you upgraded your installation of Raspbian before updating the MM? You would also have to check every module folder that has a package.json and run npm install in the module folder. This has generally worked for most of the guys with the same issue as you have.
                            • T Offline
                              thedk
                              I didnt upgrade, i made an complete new installation cause of the issue i had before.
                              Since two days the mirror has no error and everything goes fine, dont know why. I made no upgrade or similar but will do this now. Maybe the issue is gone with that.
                              Thanks for your help.
                              • mumblebajM Online
                                @thedk Please remember to check every module folder that has a package.json in it and run npm install in those folders as well.
                                • T Offline
                                  thedk
                                  I will do this.
                                  Thanks.
                                  • T Offline
                                    thedk @thedk
                                    0|mm  | npm
                                    0|mm  |  ERR! file sh
                                    0|mm  | npm
                                    0|mm  | npm
                                    0|mm  |  ERR!
                                    About a month ago and now again…
                                    Everything is up to date but the issue is still there. Each day when the Mirror starts, the error comes second for second. A reboot solves the problem the mirror is runinng without problems.
                                    Are there people where the Mirror is working für ober two months without issues? ^^
                                      sdetweil @thedk
                                      sorry, I am not quite sure I am understanding…
                                      you start the mirror (with pm2? or manually?), and it fails, with the above message
                                      and then you reboot
                                      and it runs ok…
                                      and runs ok for how long?
                                      i have 5 mirror instances, and all have been running for months without issues like this
                                      did u put updates onto your operating system, or were some applied automatically?
                                      libc.so.6 is a system library
                                      • T Offline
                                        thedk
                                        The mirror starts every day automatically with pm2 throw a smart plug and the raspberry shuts down throw corn every day.
                                        At the first start, he wont run with the log above, when i reboot the pi he is working without any problems till he shuts down at the end of the day.
                                        All updates were made by me, none automatically.
