    What is proper procedure to uninstall MM for a fresh install?
    6 Posts 2 Posters 2.5k Views 2 Watching
    • johnnyboyJ Offline
      johnnyboy
      I’ve kinda neglected my MM of late, and had the updates notification turned off…
      I now want to update my Raspbian OS and then start afresh with the updated MM version, all of which has been running for 3 years now.
      Can someone tell me the proper procedure to do this, or just point me in the right direction. I do not want anything left behind that could mess up the fresh install of MM… not wanting to simply update from old, I just want a fresh new start.
      TVMIA
        sdetweil @johnnyboy
        @johnnyboy rename MagicMirror folder to something else.
        Start install again
        Erase old MagicMirror folder when done
        johnnyboyJ 1 Reply Last reply Reply Quote 1
          johnnyboy
          Thanks… will go for that.
            johnnyboy @sdetweil
            Advisable to install Stretch… or stay with Jessie?
              sdetweil @johnnyboy
              @johnnyboy Stretch… Jesse pretty old… Buster just out
                johnnyboy @sdetweil
                @sdetweil said in What is proper procedure to uninstall MM for a fresh install?:
                Thanks. I ended up simply flashing the sd card for Stretch, and starting all over again, rather than build on what was already there… but good to know just to rename the MM folder, to re-do a fresh install.
