Setup script fails
18 Posts 6 Posters 6.6k Views 6 Watching
    sdetweil @qtin
    @qtin cool! Thanks for the update!
      dpuckett @qtin
      root@raspberrypi:~/MagicMirror# npm install
      npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
      electron-chromedriver@1.8.0 install /root/MagicMirror/node_modules/electron-chromedriver
      node ./download-chromedriver.js
      internal/modules/cjs/loader.js:964
      throw err;
      Error: Cannot find module ‘/root/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js’
      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:961:17)
      at Function.Module._load (internal/modules/cjs/loader.js:854:27)
      at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
      at internal/main/run_main_module.js:17:47 {
      code: ‘MODULE_NOT_FOUND’,
      requireStack: []
      npm WARN grunt-stylelint@0.12.0 requires a peer of stylelint@^11.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! electron-chromedriver@1.8.0 install: node ./download-chromedriver.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
      npm ERR! /root/.npm/_logs/2019-12-07T00_55_07_956Z-debug.log
      S 1 Reply Last reply Dec 7, 2019, 4:39 AM Reply Quote 0
        sdetweil @dpuckett
        @dpuckett please rename the MagicMirror folder out of the way and use the install script
        see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
        for the install command string
        A 1 Reply Last reply Dec 12, 2019, 5:12 PM Reply Quote 0
          ant62130 @sdetweil
          @sdetweil Hi,
          I have exactly the same error as @dpuckett on my freshly installed Raspberry Pi 3B+ :
          I runned the install script :
          root@raspberrypi:~# bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
          $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
          $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
          $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
          $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
          $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
          $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
          \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                  \______/
          install log being saved to /root/install.log
          No LSB modules are available.
          Updating packages ...
          Installing helper tools ...
          Lecture des listes de paquets... Fait
          Construction de l'arbre des dépendances
          Lecture des informations d'état... Fait
          build-essential est déjà la version la plus récente (12.6).
          curl est déjà la version la plus récente (7.64.0-4).
          git est déjà la version la plus récente (1:2.20.1-2+deb10u1).
          unzip est déjà la version la plus récente (6.0-23+deb10u1).
          wget est déjà la version la plus récente (1.20.1-1.1).
          Le paquet suivant a été installé automatiquement et n'est plus nécessaire :
            point-rpi
          Veuillez utiliser « sudo apt autoremove » pour le supprimer.
          0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
          Check current Node installation ...
          Node currently installed. Checking version number.
          Minimum Node version: v10.1.0
          Installed Node version: v10.15.2
          No Node.js upgrade necessary.
          Check current NPM installation ...
          NPM currently installed. Checking version number.
          Minimum npm version: V6.0.0
          Installed npm version: V6.13.4
          No npm upgrade necessary.
          Cloning MagicMirror ...
          Clonage dans 'MagicMirror'...
          remote: Enumerating objects: 331, done.
          remote: Counting objects: 100% (331/331), done.
          remote: Compressing objects: 100% (295/295), done.
          remote: Total 331 (delta 40), reused 198 (delta 22), pack-reused 0
          Réception d'objets: 100% (331/331), 662.32 KiB | 589.00 KiB/s, fait.
          Résolution des deltas: 100% (40/40), fait.
          Cloning MagicMirror Done!
          Installing dependencies ...
          internal/modules/cjs/loader.js:583
              throw err;
          Error: Cannot find module '/root/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
              at Function.Module._load (internal/modules/cjs/loader.js:507:25)
              at Function.Module.runMain (internal/modules/cjs/loader.js:742:12)
              at startup (internal/bootstrap/node.js:283:19)
              at bootstrapNodeJSCore (internal/bootstrap/node.js:743:3)
          npm ERR! errno 1
          npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
          npm ERR!
          npm ERR!     /root/.npm/_logs/2019-12-12T17_09_00_128Z-debug.log
          root@raspberrypi:~# uname -a
          Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
          root@raspberrypi:~#
          I tried to execute the command of @tcsabina which worked for him/her but no result :
          sudo npm i -g npm
          cd MagicMirror
          (Inside the MagicMirror directory)
          rm -rf node_modules/
          npm install
          All done 🙂
          S 1 Reply Last reply Dec 13, 2019, 3:15 AM Reply Quote 0
            sdetweil @ant62130
            @ant62130 please install as user pi, not root
            A 1 Reply Last reply Dec 13, 2019, 1:46 PM Reply Quote 0
              ant62130 @sdetweil
              @sdetweil Thanks for the fast reply, it works now !
              Why is the new script not present on the homepage of the website ?
              Antoine
              S 2 Replies Last reply Dec 13, 2019, 1:50 PM Reply Quote 0
                sdetweil @ant62130
                @ant62130 said in Setup script fails:
                updates take time. I’m just another user like you.
                i see new users struggling to get running, and thought I could help.
                i have submitted it, and it has been accepted for the next update, and will replace the current version.
                we’ve spent a few months testing to make sure its better.
                  sdetweil @ant62130
                  @ant62130 I have added a check for user being root… thanks again for the report and feedback
