    Error with dependencies, but it's different then the other ones just posted?!?!?
    11 Posts 3 Posters 4.2k Views 4 Watching
      stalker401
      I’m a complete noob at this, so if this is actually the same, I apologize, but to my very untrained eye, it looks different:
      Cloning MagicMirror Done!
      Installing dependencies ...
      (node:5030) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      npm WARN engine grunt-markdownlint@2.5.0: wanted: {"node":">=6","npm":">=3"} (current: {"node":"8.11.1","npm":"1.4.21"})
      npm ERR! Error: Method Not Allowed
      npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR!     at /usr/share/npm/lib/cache/add-named.js:120:12
      npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
      npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
      npm ERR! If you need help, you may report this *entire* log,
      npm ERR! including the npm and node versions, at:
      npm ERR!     <http://github.com/npm/npm/issues>
      npm ERR! System Linux 4.19.57-v7+
      npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      successfully dowloaded and extracted!
      npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
      npm ERR! tar.unpack untar error /home/pi/.npm/postcss-jsx/0.36.1/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/table/5.4.1/package.tgz
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss/lib'
      npm ERR! error rolling back  stylelint@10.1.0 { Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss/lib'
      npm ERR! error rolling back   errno: -39,
      npm ERR! error rolling back   code: 'ENOTEMPTY',
      npm ERR! error rolling back   syscall: 'rmdir',
      npm ERR! error rolling back   path: '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss/lib' }
      npm ERR! tar.unpack untar error /home/pi/.npm/log-symbols/2.2.0/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/postcss-selector-parser/3.1.1/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/camelcase-keys/4.2.0/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/is-fullwidth-code-point/3.0.0/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/autoprefixer/9.6.1/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/minimist-options/3.0.2/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/braces/3.0.2/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/ansi-regex/4.1.0/package.tgz
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/micromatch/node_modules/picomatch'
      npm ERR! error rolling back  micromatch@4.0.2 { Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/micromatch/node_modules/picomatch'
      npm ERR! error rolling back   path: '/home/pi/MagicMirror/node_modules/stylelint/node_modules/micromatch/node_modules/picomatch' }
      npm ERR! tar.unpack untar error /home/pi/.npm/emoji-regex/8.0.0/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/yargs-parser/10.1.0/package.tgz
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/meow/node_modules/normalize-package-data/lib'
      npm ERR! error rolling back  meow@5.0.0 { Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/meow/node_modules/normalize-package-data/lib'
      npm ERR! error rolling back   path: '/home/pi/MagicMirror/node_modules/stylelint/node_modules/meow/node_modules/normalize-package-data/lib' }
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/unist-util-find-all-after'
      npm ERR! error rolling back  postcss-markdown@0.36.0 { Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/unist-util-find-all-after'
      npm ERR! error rolling back   path: '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/unist-util-find-all-after' }
      > core-js@2.6.9 postinstall /home/pi/MagicMirror/node_modules/spectron/node_modules/webdriverio/node_modules/babel-runtime/node_modules/core-js
      > node scripts/postinstall || echo "ignore"
      npm ERR!
      npm ERR! not ok code 0
      Any help would be great, but I’ll be honest I need step by step instructions but yeah, I don’t know squat. Thanks a ton for your help!
        sdetweil @stalker401
        @stalker401 show us the output of npm -v and node -v please
          stalker401 @sdetweil
          @sdetweil im sorry im just so new to this. How do i get that info and show it?
          • T Offline
            tcsabina
            Just start a xterm (or any terminal) on the RPi, and type those commands in there. And copy+paste the output of those to the forum.
            Maybe you have to execute those from the Magicmirror directory, I am not sure. But if yes, in the xterm you started just type ‘cd MagicMirror’. And after that type those 2 commands.
              stalker401 @tcsabina
              @tcsabina awesome thanks. Ill get on that after work today
                stalker401
                So I ran from the MagicMirror directory and not from it:
                pi@raspberrypi:~ $ npm -v
                1.4.21
                (node:1633) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                pi@raspberrypi:~ $ node -v
                v8.11.1
                pi@raspberrypi:~ $ cd MagicMirror
                pi@raspberrypi:~/MagicMirror $ npm -v
                1.4.21
                (node:1641) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                pi@raspberrypi:~/MagicMirror $ node -v
                v8.11.1
                I hope this helps. If I screwed up somehow let me know.
                  @stalker401 npm is WAY downlevel
                  Do
                  npm i -g npm
                  Then redo the npm -v
                  Should be 6.?.?
                    stalker401
                    I ran it, and I have a feeling I screw up:
                    Not from MagicMirror:
                    pi@raspberrypi:~ $ npm i -g npm
                    (node:2262) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                    npm ERR! tar.unpack untar error /home/pi/.npm/npm/6.10.1/package.tgz
                    npm ERR! Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/npm'
                    npm ERR!  { Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/npm'
                    npm ERR!   errno: -13,
                    npm ERR!   code: 'EACCES',
                    npm ERR!   syscall: 'mkdir',
                    npm ERR!   path: '/usr/local/lib/node_modules/npm',
                    npm ERR!   fstream_type: 'Directory',
                    npm ERR!   fstream_path: '/usr/local/lib/node_modules/npm',
                    npm ERR!   fstream_class: 'DirWriter',
                    npm ERR!   fstream_stack:
                    npm ERR!    [ '/usr/lib/nodejs/fstream/lib/dir-writer.js:35:25',
                    npm ERR!      '/usr/lib/nodejs/mkdirp/index.js:46:53',
                    npm ERR!      'FSReqWrap.oncomplete (fs.js:152:21)' ] }
                    npm ERR!
                    npm ERR! Please try running this command again as root/Administrator.
                    npm ERR! command "/usr/bin/node" "/usr/bin/npm" "i" "-g" "npm"
                    npm ERR! path /usr/local/lib/node_modules/npm
                    npm ERR! syscall mkdir
                    npm ERR! fstream_path /usr/local/lib/node_modules/npm
                    npm ERR! fstream_type Directory
                    npm ERR! fstream_class DirWriter
                    npm ERR! code EACCES
                    npm ERR! errno -13
                    npm ERR! stack Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/npm'
                    npm ERR! fstream_stack /usr/lib/nodejs/fstream/lib/dir-writer.js:35:25
                    npm ERR! fstream_stack /usr/lib/nodejs/mkdirp/index.js:46:53
                    npm ERR! fstream_stack FSReqWrap.oncomplete (fs.js:152:21)
                    npm ERR! Error: EACCES: permission denied, open 'npm-debug.log'
                    npm ERR!  { Error: EACCES: permission denied, open 'npm-debug.log'
                    npm ERR!   syscall: 'open',
                    npm ERR!   path: 'npm-debug.log' }
                    npm ERR!
                    npm ERR! path npm-debug.log
                    npm ERR! syscall open
                    npm ERR! errno -13
                    npm ERR! stack Error: EACCES: permission denied, open 'npm-debug.log'
                    npm ERR!
                    npm ERR!     /home/pi/npm-debug.log
                    1.4.21
                    (node:2273) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                    and than from MagicMirror:
                    pi@raspberrypi:~/MagicMirror $ npm i -g npm
                    (node:2633) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                    npm ERR!
                    npm ERR! errno -13
                    npm ERR!
                    1.4.21
                    (node:2688) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                      stalker401
                      Ok figured out I’m an idiot:
                      pi@raspberrypi:~/MagicMirror $ sudo npm i -g npm
                      (node:2766) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                      npm WARN package.json path-is-inside@1.0.2 No README data
                      npm WARN package.json sorted-object@2.0.1 No README data
                      npm WARN package.json config-chain@1.1.12 No license field.
                      npm WARN package.json cyclist@0.2.2 No license field.
                      npm WARN package.json json-schema@0.2.3 No license field.
                      npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
                      npm WARN package.json qrcode-terminal@0.12.0 No license field.
                      npm WARN package.json string_decoder@1.2.0 string_decoder is also the name of a node core module.
                      /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                      /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                      npm@6.10.1 /usr/local/lib/node_modules/npm
                      pi@raspberrypi:~/MagicMirror $ sudo npm -v
                      6.10.1
                      I’m guessing I need to run this not from MagicMirror and rerun the bash for MagicMirror again?
                        stalker401
                        Ok so here’s what I got:
                        pi@raspberrypi:~ $ sudo npm i -g npm
                        /usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
                        /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                        + npm@6.10.1
                        added 433 packages from 823 contributors in 44.875s
                        pi@raspberrypi:~ $ sudo npm -v
                        6.10.1
                        Do I just need to change the name of hte MagicMirror folder and rerun the bash again?
                          @stalker401 sorry, I should have mentioned u might need sudo.
                          But you got it!
                          Rename and rerun bash is the easiest
