    Problems with starting pm2 start mm.sh
    27 Posts 7 Posters 14.8k Views 7 Watching
      madoXX
      i made everything link written in this tutorial
      https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
      but i stack here:
      Starting your MagicMirror with PM2
      Simply start your mirror with the following command:
      pm2 start mm.sh
      You mirror should now boot up and appear on your screen after a few seconds.
      It doesn’t
      when i enter pm2 start mm.sh i receive the following message:
      [PM2] Starting /home/pi/mm.sh in fork_mode (1 instance)
      [PM2] Done.
      │ Name │ id │ mode │ status │ ↺ │ cpu │ memory │
      │ mm │ 0 │ fork │ online │ 0 │ 0% │ 2.8 MB │
      Use pm2 show <id|name> to get more details about an app
      thats it.
      When i reboot i see the Magic Mirror Screen but the Raspi starts always the standard desktop.
      Any suggestions?
      Thank you very much!
      • CyruS1337C Offline
        CyruS1337 Project Sponsor
        Did you also follow this point:
        Starting PM2 on boat
        To make sure PM2 can do it’s job when (re) booting your operating system, it needs to be started on boot. Luckily, PM2 has a handy helper for this.
        pm2 startup
        PM2 wants to show you a command you need to execute.
          sdetweil
          @madoXX said in Problems with starting pm2 start mm.sh:
          /home/pi/mm.sh
          what does this file look like? can u copy the content here?
            madoXX @CyruS1337
            @CyruS1337 said in Problems with starting pm2 start mm.sh:
            pm2 startup
            Thanks for your reply. For the moment i want to know why it doesn’t even start, when i try to start it manually.
            Moreover, here the content of the file mm.sh (saved in /home/pi)
            cd ~/MagicMirror
            DISPLAY=:0 npm start
              sdetweil @madoXX
              cd ~/MagicMirror
              change that 1st line to be
              cd /home/pi/MagicMirror
              pm2 is running under root at the time of startup
                madoXX @sdetweil
                @sdetweil said in Problems with starting pm2 start mm.sh:
                cd ~/MagicMirror
                changed it, saved and made a reboot. nothing changed.
                when i write pm2 start i receive the following message:
                [PM2][ERROR] File ecosystem.config.js not found
                │ App name │ id │ version │ mode │ pid │ status │ restart │ uptime │ cpu │ mem │ user │ watching │
                │ mm │ 0 │ N/A │ fork │ 838 │ online │ 0 │ 3m │ 0% │ 2.4 MB │ pi │ disabled │
                  sdetweil @madoXX
                  ok, seems pm2 is not setup right
                  1st make sure script works
                  is it executable?
                  chmod +x mm.sh
                  /home/pi/mm.sh &
                  (and stop it)
                  then
                  pm2 remove 0
                  pm2 startup
                     this will return a command u need to execute (cut/paste)
                  pm2 start /home/pi/mm.sh
                  pm2 save
                  then
                  pm2 list
                  nothing running
                  pm2 start mm
                  should start ok
                  reboot
                    madoXX
                    is it executable?
                    chmod +x mm.sh
                    ok, done
                    /home/pi/mm.sh &
                    (and stop it)
                    then
                    don’t get this…
                    should i enter
                    pm2 stop /home/pi/mm.sh &
                    pm2 remove 0
                    when i enter this, this appears:
                    [PM2] Command not found
                    usage: pm2 [options]
                    pm2 -h, --help all available commands and options
                    pm2 examples display pm2 usage examples
                    pm2 -h help on a specific command
                    Access pm2 files in ~/.pm2
                    [1]+ Fertig pm2 stop /home/pi/mm.sh
                    pm2 startup
                    ok, had to enter this one:
                    sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                    After the enter this one appeared:
                    [PM2] Init System found: systemd
                    Platform systemd
                    Template
                    [Unit]
                    Description=PM2 process manager
                    Documentation=https://pm2.keymetrics.io/
                    After=network.target
                    [Service]
                    Type=forking
                    User=pi
                    LimitNOFILE=infinity
                    LimitNPROC=infinity
                    LimitCORE=infinity
                    Environment=PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                    Environment=PM2_HOME=/home/pi/.pm2
                    PIDFile=/home/pi/.pm2/pm2.pid
                    Restart=on-failure
                    ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
                    ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
                    ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
                    [Install]
                    WantedBy=multi-user.target
                    Target path
                    /etc/systemd/system/pm2-pi.service
                    Command list
                    [ ‘systemctl enable pm2-pi’ ]
                    [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
                    [PM2] Making script booting at startup…
                    Executing: systemctl enable pm2-pi…
                    [PM2] [v] Command successfully executed.
                    [PM2] Freeze a process list on reboot via:
                    $ pm2 save
                    [PM2] Remove init script via:
                    $ pm2 unstartup systemd
                    here this is the result:
                    [PM2] Applying action restartProcessId on app [mm](ids: 0)
                    [PM2] mm ✓
                    [PM2] Process successfully started
                    │ mm │ 0 │ N/A │ fork │ 15797 │ online │ 0 │ 0s │ 0% │ 2.4 MB │ pi │ disabled │
                    pm2 save
                    Result
                    [PM2] Saving current process list…
                    [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                    pm2 list
                    nothing running
                    Yes there is the mm running:
                    │ mm │ 0 │ N/A │ fork │ 15797 │ online │ 0 │ 103s │ 0% │ 2.4 MB │ pi │ disabled │
                    pm2 start mm
                    should start ok
                    perhaps no…
                    [PM2] mm ✓
                    │ mm │ 0 │ N/A │ fork │ 16995 │ online │ 1 │ 0s │ 0% │ 2.5 MB │ pi │ disabled │
                    Thanks anyway for your help!
                      sdetweil @madoXX
                      @madoXX does it restart on boot?
                      pm2 remove 0
                      should have been
                      pm2 delete 0
                      and yep, needed a stop after the pm2 save
                        madoXX @sdetweil
                        pm2 remove 0
                        should have been
                        pm2 delete 0
                        no, the boot menu from the magic mirror appears (booting up), no error but it goes straight to the desktop.
                        something strang here
                        then
                        pm2 list
                        nothing running
                        In fact the themm.sh is running caus i startet it above
                        • 1 / 3
