    Problems with starting pm2 start mm.sh
    27 Posts 7 Posters 16.6k Views 7 Watching
      sdetweil @Raksasas
      @Raksasas should be executing those while in the MagicMirror folder
        Raksasas @sdetweil
        Looking over the “Auto Start” page I do not see where it states that the pm2 commands are to be run while inside the MagicMirror folder.
        With you stating that it seems to be saying that the “mm.sh” script needs to be ran from inside the “MagicMirror” too. Again the “Auto Start” page shows that it was created inside the ‘home’ (~) folder. So one would think/presume it can be ran from inside the “home” folder also.
        Either way I will give it a go.
        mumblebajM S 2 Replies Last reply Reply Quote 0
        • mumblebajM Offline
          mumblebaj Module Developer @Raksasas
          @Raksasas My mm.sh resides in my /pi/ folder and not in the MagicMirror folder so should work. It might be that there was an error while you were setting up pm2 or setting up the autostart perhaps?
            sdetweil @Raksasas
            @Raksasas it was the
            pm2 start installers/mm.sh
            That needed to be done from the MagicMirror folder.
            Cause I ‘ASSUMED’ if u were working on mm, you would always be in that folder.
            installers folder is in mm, not in user home
              Raksasas
              Part 1:
              Just tried the
              pm2 save
              From within the “MagicMirror” folder and no change. MagicMirror starts and at reboot it does not automaticly start
              See below for my fix
              Part 2:
              @mumblebaj
              This seems possible. So i re-ran
              sudo npm install -g pm2
              pm2 startup
              After running “pm2 startup” this time I noticed the following:
              To setup the Startup Script, copy/paste the following command:
              sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
              So I ran that and followed with the “pm2 start mm.sh” and “pm2 save”. Well now it is auto starting on reboot.
              S mumblebajM 2 Replies Last reply Reply Quote 0
                sdetweil @Raksasas
                @Raksasas great news!
                  @Raksasas Exellent. Great it is working now.
                  • T TDMPro2K referenced this topic on
