    new update/upgrade script, ready for testing
    328 Posts 27 Posters 650.2k Views 24 Watching
      sdetweil @BKeyport
      @BKeyport gotta be me… I will look at in about 45 minutes, when I get home.
      Thx for the report
        @sdetweil >local version 2.10.1 already same as master 2.10.1
        u are upgrading from/to the same version, so no work is done…
        if u want to force it to apply changes (again) then use force as the parm
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
        • BKeyportB Online
          @sdetweil Correct, but isn’t it supposed to run for modules, too?
            sdetweil @BKeyport
            @BKeyport not if it’s doing nothing
            • BKeyportB Online
              @sdetweil oh, gotcha.
              Then I’ll manually update the module for now - would you be able to add that in at a later time? I’d love to be able to have a quick script to run through my modules and update 'em as they call for updates.
              Thanks!
                sdetweil @BKeyport
                @BKeyport use force. It will do it.
                  bdream
                  Hi Sam! I run your update script an my Pi0
                  Seems it works fine :ok_hand: but my screen show up only the standard Raspian Desktop :crying_face:
                  pm2 restart MagicMirror
                  looks good
                  [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                  [PM2] [MagicMirror](0) ✓
                  │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                  │ 0   │ MagicMirror    │ default     │ 2.12.0  │ fork    │ 19770    │ 0s     │ 122… │ online    │ 0%       │ 2.5mb    │ pi       │ enabled  │
                  what is I’m doing wrong?
                  Many thanks!!!
                  cheers, bdream
                    sdetweil @bdream
                    @bdream something is wrong, 122 restarts 0 uptime.
                    do
                    pm2 stop 0
                    pm2 logs --lines=100
                      bdream
                      here is
                      pi@RasPiZeroW:~/MagicMirror $ pm2 logs --lines=100
                      [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
                      /home/pi/.pm2/pm2.log last 100 lines:
                      PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-07-03T13:25:01: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-07-03T13:28:36: PM2 log: [Watch] Stop watching MagicMirror
                      PM2        | 2020-07-03T13:28:36: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-07-03T13:28:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-07-03T13:28:37: PM2 log: pid=29676 msg=process killed
                      /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                      0|MagicMir |
                      0|MagicMir | > magicmirror@2.12.0 start /home/pi/MagicMirror
                      0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      0|MagicMir |
                      0|MagicMir |
                      /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                      0|MagicMir | npm ERR! errno ENOENT
                      0|MagicMir | npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                      0|MagicMir | npm ERR! spawn ENOENT
                      0|MagicMir | npm ERR! Failed at the magicmirror@2.12.0 start script.
                      0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                      0|MagicMir |
                      0|MagicMir | npm ERR! A complete log of this run can be found in:
                      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_27_39_492Z-debug.log
                      0|MagicMir | sh: 1: ./node_modules/.bin/electron: not found
                      0|MagicMir | npm ERR! code ELIFECYCLE
                      0|MagicMir | npm ERR! syscall spawn
                      0|MagicMir | npm ERR! file sh
                      0|MagicMir |
                      0|MagicMir |
                      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_28_26_351Z-debug.log
                      cheers, bdream
                        sdetweil @bdream
                        @bdream hm. looks like my upgrade script failed to restore the start script change
                        edit package.json
                        change the start line to
                        "start": "./run-start.sh",
                        then
                        pm2 flush
                        pm2 start 0
                        I see the bug, but am on my phone right now and will have to fix it later
                        • 26
                        • 27
                        • 28
                        • 29
                        • 30
                        • 31
                        • 32
                        • 33
                        • 28 / 33
