    Error code EADDRINUSE
    41 Posts 3 Posters 13.7k Views 3 Watching
    • P Offline
      PXNDA
      I have just added MMM-Remote-Control but I started to get this error:EADDRINUSE. I am using a Windows computer. 0_1564420452217_Capture.PNG
      • P Offline
        PXNDA
        I also found this error code in the logs ELIFECYCLE. I’m using Git Bash.
        Entire log:
        1 verbose cli [ 'C:\\Program Files\\nodejs\\node.exe',
        1 verbose cli   'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
        1 verbose cli   'start' ]
        2 info using npm@6.9.0
        3 info using node@v10.16.0
        5 info lifecycle magicmirror@2.8.0~prestart: magicmirror@2.8.0
        6 info lifecycle magicmirror@2.8.0~start: magicmirror@2.8.0
        7 verbose lifecycle magicmirror@2.8.0~start: unsafe-perm in lifecycle true
        8 verbose lifecycle magicmirror@2.8.0~start: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;C:\Users\user1\MagicMirror\node_modules\.bin;C:\Program Files\Git\cmd;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\dotnet\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\nodejs\;C:\Program Files\Git\cmd;C:\Users\user1\AppData\Local\Microsoft\WindowsApps;C:\Users\user1\AppData\Roaming\npm
        9 verbose lifecycle magicmirror@2.8.0~start: CWD: C:\Users\user1\MagicMirror
        10 silly lifecycle magicmirror@2.8.0~start: Args: [ '/d /s /c', 'sh run-start.sh' ]
        11 silly lifecycle magicmirror@2.8.0~start: Returned: code: 1  signal: null
        12 info lifecycle magicmirror@2.8.0~start: Failed to exec start script
        13 verbose stack Error: magicmirror@2.8.0 start: `sh run-start.sh`
        13 verbose stack Exit status 1
        13 verbose stack     at EventEmitter.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\index.js:301:16)
        13 verbose stack     at EventEmitter.emit (events.js:198:13)
        13 verbose stack     at ChildProcess.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
        13 verbose stack     at ChildProcess.emit (events.js:198:13)
        13 verbose stack     at maybeClose (internal/child_process.js:982:16)
        13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        14 verbose pkgid magicmirror@2.8.0
        15 verbose cwd C:\Users\user1\MagicMirror
        16 verbose Windows_NT 10.0.18362
        17 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "start"
        18 verbose node v10.16.0
        19 verbose npm  v6.9.0
        20 error code ELIFECYCLE
        21 error errno 1
        22 error magicmirror@2.8.0 start: `sh run-start.sh`
        22 error Exit status 1
        23 error Failed at the magicmirror@2.8.0 start script.
        23 error This is probably not a problem with npm. There is likely additional logging output above.
        24 verbose exit [ 1, true ]
        • P Offline
          PXNDA
          I cloned MagicMirror and copied the run-start.sh into the original but it still doesn’t work.
          Entire error:
          { Error: listen EADDRINUSE 0.0.0.0:8080
              at Server.setupListenHandle [as _listen2] (net.js:1330:14)
              at listenInCluster (net.js:1378:12)
              at doListen (net.js:1492:7)
              at process._tickCallback (internal/process/next_tick.js:63:19)
              at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
              at startup (internal/bootstrap/node.js:241:19)
              at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
            errno: 'EADDRINUSE',
            code: 'EADDRINUSE',
            syscall: 'listen',
            address: '0.0.0.0',
            port: 8080 }
          S mumblebajM 2 Replies Last reply Reply Quote 0
            sdetweil @PXNDA
            @PXNDA that means something is already using port 8080. Maybe u have pm2 running magicmirror already
            • mumblebajM Offline
              mumblebaj Module Developer @PXNDA
              @PXNDA As @sdetweil mentioned, the EADDRINUSE means that something is already listening on port 8080. You need to check what it is and kill the process and try restarting the MM again.
              • P Offline
                PXNDA
                Thank you. It fixed the error code but now it is asking me to create a config file when I already have one.
                  sdetweil @PXNDA
                  @PXNDA u have a syntax error
                  From the MagicMirror folder do
                  npm run check:config
                  Fix errors top down, rerun til no errors
                  • P Offline
                    PXNDA
                    Thanks it worked but I now have a black screen, with nothing on it.
                      sdetweil @PXNDA
                      @PXNDA open the developers console, ctrl-shift-i, select the console tab and scroll up to find any errors, usually in red text
                      • P Offline
                        PXNDA
                        I got this warning:
                        Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                        Policy set or a policy with “unsafe-eval” enabled. This exposes users of
                        this app to unnecessary security risks.
                        For more information and help, consult
                        https://electronjs.org/docs/tutorial/security.
                        This warning will not show up
                        once the app is packaged.
                        • 1 / 5
