SOLVED Error code EADDRINUSE
@PXNDA don’t care about that… looking for errors
are you still getting the eaddressinuse error in the terminal window?
No, and i only have that warning.
select the console tab… you are on the elements tab
same thing:
C:\Users\user1\MagicMirror\node_modules\electron\dist\resources\electron.asar\renderer\security-warnings.js:184Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
Policy set or a policy with “unsafe-eval” enabled. This exposes users of
this app to unnecessary security risks.For more information and help, consult
https://electronjs.org/docs/tutorial/security.
This warning will not show up
once the app is packaged.
warnAboutInsecureCSP @ C:\Users\user1\MagicMirror\node_modules\electron\dist\resources\electron.asar\renderer\security-warnings.js:184 -
@PXNDA change the filter from defaults to all
What do you mean?
@PXNDA there is a field called filter, center … there should be a lot of info in the console…
the very top row, elements, console, sources, network, …
@PXNDA not the word all, next to it there is a drop down says default levels
