    Error code EADDRINUSE
    41 Posts 3 Posters 14.6k Views 3 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @PXNDA
      @PXNDA As @sdetweil mentioned, the EADDRINUSE means that something is already listening on port 8080. You need to check what it is and kill the process and try restarting the MM again.
      • P Offline
        PXNDA
        Thank you. It fixed the error code but now it is asking me to create a config file when I already have one.
          sdetweil @PXNDA
          @PXNDA u have a syntax error
          From the MagicMirror folder do
          npm run check:config
          Fix errors top down, rerun til no errors
          • P Offline
            PXNDA
            Thanks it worked but I now have a black screen, with nothing on it.
              sdetweil @PXNDA
              @PXNDA open the developers console, ctrl-shift-i, select the console tab and scroll up to find any errors, usually in red text
              • P Offline
                PXNDA
                I got this warning:
                Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                Policy set or a policy with “unsafe-eval” enabled. This exposes users of
                this app to unnecessary security risks.
                For more information and help, consult
                https://electronjs.org/docs/tutorial/security.
                This warning will not show up
                once the app is packaged.
                  sdetweil @PXNDA
                  @PXNDA don’t care about that… looking for errors
                  are you still getting the eaddressinuse error in the terminal window?
                  • P Offline
                    PXNDA
                    No, and i only have that warning.
                    • P Offline
                      PXNDA
                        sdetweil
                        select the console tab… you are on the elements tab
                        • 4 / 5
