    My MagicMirror screen keeps turning off
    20 Posts 4 Posters 9.1k Views 4 Watching
    • E Offline
      EhsanMomeni81 @evroom
      @evroom
      I edited the autostart which was stated in the MagicMirror guide
      sudo nano /etc/xdg/lxsession/LXDE/autostart
      evroomE 1 Reply Last reply Reply Quote 0
      • evroomE Offline
        evroom @EhsanMomeni81
        @EhsanMomeni81
        For Debian buster that seems to be right.
        For Debian stretch it is
        /home/pi/.config/lxsession/LXDE-pi/autostart
        On my Debian buster Pi with official RPI 7 inch screen, I have this for screen off after15 minutes.
        So, your xset settings seem right; have them like that on my other MagiMirror install (on Debian stretch) too.
        pi@raspberrypi:~ $ cat /etc/xdg/lxsession/LXDE-pi/autostart
        @lxpanel --profile LXDE-pi
        @pcmanfm --desktop --profile LXDE-pi
        @xscreensaver -no-splash
        point-rpi
        @xset s 900
        @xset s blank
        @xset -dpms
        @sdetweil made install scripts, so I guess he knows a bit more.
        MagicMirror version: 2.33.0
        Test environment:
        MagicMirror version: v2.33.0
        S E 2 Replies Last reply Reply Quote 0
          sdetweil @evroom
          @evroom not for screen stuff yet
          • E Offline
            @evroom
            Sorry, but Debian buster and Debian stretch?
            I have a cronjob to turn off the screen at 11 pm until 6 am, which works, but other than that I want the screen to be on. Is it possible to change 900 to 61 200 (17 h) instead?
            • evroomE Offline
              evroom
              @EhsanMomeni81 said in My MagicMirror screen keeps turning off:
              I guess you downloaded and installed an image with Debian, like from
              https://www.raspberrypi.org/downloads/raspbian/
              Debian Buster is the latest Debian version.
              With lsb_release -ayou can find out which version you have.
              If your cronjob works for turning on / off the screen, then I guess you do not need to use the @xset parameters to turn off the screen.
              This is what I currently have:
              For Debain Stretch (screen always on):
              $ cat /home/pi/.config/lxsession/LXDE-pi/autostart
              @point-rpi
              @unclutter -display :0 -idle 3 -root -noevents
              @xset s noblank
              @xset s off
              @xset -dpms
              For Debian Buster (screen off after 900 seconds):
              point-rpi
              @xset s 900
              @xset s blank
              @xset -dpms
              Not sure what the other entries do, I just appended the @xset lines to the existing entries.
              Will try what happens when I remove them a bit later.
              Test environment:
              • evroomE Offline
                evroom @evroom
                @evroom said in My MagicMirror screen keeps turning off:
                To answer myself.
                lxpanel        0.10.0-2+rpt4 armhf        LXDE panel
                pcmanfm        1.3.1-1+rpt7 armhf        extremely fast and lightweight file manager
                point-rpi      0.20160905   armhf        Locate the mouse pointer over the menu button
                xscreensaver - not installed
                Using Debian Buster and a RPI 7 inch display, these settings should work for ‘screen always on’:
                @point-rpi          # locate the mouse pointer over the menu button
                @xset s off         # don't activate screensaver
                @xset -dpms         # disable DPMS (Energy Star) features.
                @xset s noblank     # don't blank the video device
                I left @point-rpias it sounds useful somehow; for screensaver settings not needed though.
                Will test it now.
                Test environment:
                • evroomE Offline
                  evroom @evroom
                  @evroom
                  Talking to myself :-)
                  The settings for Buster are not working.
                  My display goes to sleep after 10 minutes.
                  Perhaps because it isn’t a HDMI connected monitor.
                  I found 2 interesting files though:
                  pi@raspberrypi:~ $ ls -als /home/pi/.xsession-errors
                  4 -rw------- 1 pi pi 2426 Aug  1 12:30 /home/pi/.xsession-errors
                  pi@raspberrypi:~ $ ls -als /home/pi/.cache/lxsession/LXDE-pi/run.log
                  20 -rw------- 1 pi pi 17988 Aug  1 12:30 /home/pi/.cache/lxsession/LXDE-pi/run.log
                  Also see that this file is being used, so that seems right:
                  Test environment:
                  • evroomE Offline
                    evroom @evroom
                    @evroom
                    This works (running for 100 minutes at the moment of posting):
                    $ sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
                    @touch /home/pi/.started_etc_xdg_lxsession_LXDE-pi_autostart
                    @point-rpi
                    @xset -dpms
                    @xset s off
                    @xset s noblank
                    Note: the autostart file does not like comments.
                    Reboot:
                    $ sudo reboot
                    After reboot is finished, check:
                    $ ls -als /home/pi/.started_etc_xdg_lxsession_LXDE-pi_autostart
                    That will tell if the autostart file was used (timestamp should match reboot time).
                    Then check for set errors:
                    $ grep xset /home/pi/.cache/lxsession/LXDE-pi/run.log
                    It should say 3 times Launching xset, with 3 times exit 0 (for every set entry in the autostart file).
                    Works for Raspberry Pi 7" Touchscreen Display.
                    $ lsb_release -a
                    No LSB modules are available.
                    Distributor ID:	Raspbian
                    Description:	Raspbian GNU/Linux 10 (buster)
                    Release:	10
                    Codename:	buster
                    Test environment:
                    • E Offline
                      EhsanMomeni81
                      Wow, that’s a lot to take in. Thank you so much for your help, I’m going to try this during the week.
                      • E Offline
                        @evroom
                        @point-rpi
                        @xset -dpms
                        @xset s off
                        @xset s noblank
                        I tried the code above, and it works on stretch, I screen doesn’t turn off. But my cronjob acts funny. Last night when I look at it after it was supposed to be turned off, the backlight was on but everything else was dark. Don’t really know whats going on, but I’ll take a new look tonight.
