    Magic mirror not starting on boot!!
    4 Posts 3 Posters 1.5k Views 4 Watching
    • M
      mishkalidas Banned
      I installed MM from the bash command on the magic mirror 2 homepage a few weeks ago. It was working great for a few days, a restart would bring MM back up once it loaded. I finally got around to building the actual enclosure and mirror last night. Plugged everything in and started up the Pi and nothing, Raspbian loads up but no MM. Instead of troubleshooting I did a fresh install of OS and MM. Starts after install but after a reboot nothing. I’ve tried again multiple times with different sd cards and different Pi’s but the same result everytime. Sometimes I can manually load up MM from command prompt but sometimes it doesn’t work at all. Any idea what I’m doing wrong here? https://sarkariresult.onl/
      S mumblebajM 2 Replies Last reply Reply Quote 0
        sdetweil @mishkalidas
        @mishkalidas i don’t know, PM2 is such a pain in the rear…
        can u do
        pm2 logs
        and show the output
        • mumblebajM
          mumblebaj Module Developer @mishkalidas
          @mishkalidas Are you perhaps looking for this? AutoStart MagicMirror with PM2 ?
            sdetweil
            Try the new pm2 setup script
            See here
            https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
