    Hello Pre-existing Google Home setup
    4 Posts 5 Posters 1.0k Views 5 Watching
    • D
      dangquan091
      I am looking into building a smart mirror within the next month and would like to have google home functionality integrated. I have been unable to find any information regarding a smart mirror using a pre-existing google home mini. I have only seen them using the google AIY voice kit. I am wondering if the same can be accomplished with my google home mini as has been done with the AIY kit.
      Thanks.
      Reply Quote 1
        A Former User
        The easiest way (I think) is to use IFTTT
        Requirements:
        • Static IP/Domain or DDNS or ngrok or dataplicity.io(+nginx) for your MM
          • your mirror should be accessible from outside of your home network.
        • IFTTT account
        • MMM-Remote-control or MMM-NotificationTrigger or some module which can be receive and interpret IFTTT message to some notifications for MM control. Or you can build your own
        How to:
        1. Give external accessible URL to your MM. (See the requirements)
        2. Make an IFTTT recipe;
        • Google Assistant for THIS, Web Hook for THAT
        • Web hook url should be your MM’s URL
        1. Set your MMM-Remote-Control or MMM-NotificationTrigger to receive IFTTT messages and translate it to control your MM.
        You can make some orders like “Ok google, Turn off the screen”, “Hey Google, Next page.”
        Harder way is to make Google Actions for MM. But not recommend personally. It would be VERY VERY HARD stuffs for non-developer. And you need to use Firebase or something similar cloud server or at least you should run your own dedicated server to host your action.
        • X
          xpaceone
          This post is deleted!
          • R
            rareskyone
            On your phone, open the Google Home app. In the Home View tab (left-most bottom tab, with the house icon), tap Settings next to the Add shortcut. Tap Home members. Tap the + in the top right corner to add a new home member.
