    Magic Mirror only shows black screen
    12 Posts 7 Posters 5.9k Views 6 Watching
      maddinmirror
      Hey,
      i’m fairly new to the scene. After working on the config file for the whole day it suddenly wouldn’t start anymore. No config file error. Just a black screen.
      I ran my config file through: https://esprima.org/demo/validate.html
      and it said valid.
      pi@raspberrypi:~ $ cd ~/MagicMirror
      > magicmirror@2.8.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.8.0
      Loading config ...
      Loading module helpers ...
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
      App threw an error during load
          at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (internal/modules/cjs/loader.js:528:25)
          at Module.require (internal/modules/cjs/loader.js:658:17)
          at require (internal/modules/cjs/helpers.js:20:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:6:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:94:3)
          at Module._compile (internal/modules/cjs/loader.js:711:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
          at Module.load (internal/modules/cjs/loader.js:620:32)
      { Error: Cannot find module 'node_helper'
          at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
      Launching application.
      Shutting down server...
      Can anyone tell me why the file can’t be read
      mumblebajM Mykle1M 2 Replies Last reply Reply Quote 0
        AxLed Module Developer
        @maddinmirror
        Can you post your config? Make sure all private key or calendar links are removed or changed (xxx) before posting.
        AxLED
        • mumblebajM Online
          mumblebaj Module Developer @maddinmirror
          @maddinmirror So, a few things. Is this a fresh install? Did you run npm install in the MagicMirror after the install? Can you do a shit+ctrl+i to open the developer console? Select the Console Tab and scroll up and look for any errors usually marked in red.
            Mykle1 Project Sponsor Module Developer @maddinmirror
            @maddinmirror said in Magic Mirror only shows black screen:
            Undo you’re changes to the config.js file to the point where it was last working.
            • idoodlerI Offline
              idoodler Module Developer
              Here are a few things to do.
              • Check if the Server is still running
                • On the Raspberry Pi open a browser and visit localhost:8080 If you see a black screen the server is still running which is good…
              • Check your changes with git status. Any changes that you didn’t make on purpose? (Especially check the updatenotification module Validate them and revert them if needed
              • Rename your config _config.js (Or someting…) to force the MagicMirror to load the default config.js, check if the expected config file error appears
              • Meditate over your changes you might miss an obvious error in your code
              • Post the censored config.js file here
              • ? Offline
                A Former User
                Your MM has been missing modules/node_modules/node_helper/index.js. (I don’t know why)
                You can copy https://github.com/MichMich/MagicMirror/blob/master/modules/node_modules/node_helper/index.js then paste it as new file and save it to MagicMirror/modules/node_modules/node_helper/index.js.
                Or reinstall MM.
                  sdetweil @Guest
                  @Sean u meant node_helper/index.js
                  Right?
                  • ? Offline
                    A Former User @sdetweil
                    @sdetweil yes. Sorry. my mistypo.
                      sdetweil
                      So the correct path is
                      MagicMirror/node_modules/node_helper/index.js
                      • ? Offline
                        @sdetweil corrected. Thanks. :D
                          maddinmirror @Guest
                          @Sean Thank you so much. That worked and it’s running again!
                          • mumblebajM Online
                            @maddinmirror Glad you managed to get it working again. Can you mark the post as Solved if you are happy with the solution?
