    Twice now the Electron screen has loaded 'Pure-White'
    5 Posts 4 Posters 2.0k Views 4 Watching
    • ? Offline
      A Former User
      Does anyone have any idea what could cause this?
      • Consider the config file has ‘no’ modules or ‘has plenty’ so its not module related as far as i can tell.
      And best way to revert it to black other than to clone files, delete MM and re-clone back in to place…
      • C Offline
        chrisyy
        This is not much info. Do u have any logs in the MagicMirror folder?
        I think this is not related to modules. What do u change when it gets white again after recloning?
          DanielG
          This post is deleted!
            bhepler Module Developer @Guest
            @wjdw87 I had this happen a few times when I was attempting to get the motiondetection module to work. I suspect it has something to do with the video driver, but I’m not sure. I ended up having to reboot the Pi to get the white screen to go away.
            I have since increased my GPU memory to 192 and I haven’t had the problem since. If you wish to try this, edit the /boot/config.txt file and either modify or add gpu_mem=192 to the file. In my case, this value was towards the bottom of the file.
            Please do let me know if this works.
            • ? Offline
              A Former User
              Hi all, i suspected it was something to do with electron being corrupted with some work we have been doing compiling both the ai - home auto - and mm together.
              I simply deleted the folder (mm) reinstalled MM and now all appears to be working fine, that is until i being installing the modules for MM :P
              Bhepler, great point, could have been that also
