    MMM-MyCommute
    22 Posts 4 Posters 7.2k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      Good Morning
      I have the module MMM-MyCommute installed on my 3 PIs. It also works on two out of three PIs. I do not know that the module works better on the second PI. I have already made the settings for a PI that runs MMM-MyCommute properly. Unfortunately, it does not work on the PI. Can someone help me please, that would be my configuration:
        module: 'MMM-MyCommute',
        position: 'top_left',
          apikey: 'API_KEY',
          origin: 'start',
          startTime: '04:00',
          endTime: '08:00',
      	travelTimeFormat: 'h[h]:m[min]',
      	colorCodeTravelTime: true,
      	showSummary: true,
          hideDays: [0,6],
          destinations: [
              destination: 'destination',
              label: 'Lisa Arbeit über Autobahn',
      		alternatives: true,
      		startTime: '05:00',
      		endTime: '08:00',
              label: 'Lisa Arbeit über Oensingen',
      		color: "#82BAE5",
      		waypoints: 'via:Oltenstrasse, 4702 Oensingen | via:Oltenstrasse, 4538 Oberbipp'
              label: 'Lisa Arbeit über Kestenholz',
      		startTime: '05:00',
      		waypoints: 'via:Oensingerstrasse, 4703 Kestenholz'
      		color: "#DB7093",
      		waypoints: 'via:Wangenstrasse, 4913 Bannwil'
        no ideas? Or can I do something that can help you to find the mistake?
          sdetweil @CyruS1337
          @CyruS1337 what does ‘does not run’ mean?
          did u open the developers console and look for any errors reported?
            If I access the MagicMirror directly via Putty do I have to enter npm start dev or how?
              sdetweil @CyruS1337
              @CyruS1337 yes, do
              cd ~/MagicMirror
              export DISPLAY=:0
              npm start dev
                @sdetweil said in MMM-MyCommute:
                export DISPLAY=:0
                That comes out when I enter npm start dev
                > magicmirror@2.8.0 start /home/pi/MagicMirror
                > sh run-start.sh "dev"
                Starting MagicMirror: v2.8.0
                Loading config ...
                Loading module helpers ...
                Module helper loaded: MMM-WatchDog
                Module helper loaded: MMM-Remote-Control
                Module helper loaded: MMM-SystemStats
                Module helper loaded: MMM-MyCommute
                Module helper loaded: MMM-GoogleMapsTraffic
                Module helper loaded: MMM-DarkSkyForecast
                Module helper loaded: MMM-MyCalendar
                All module helpers loaded.
                Server started ...
                Connecting socket for: MMM-WatchDog
                Starting module helper: MMM-WatchDog
                Connecting socket for: MMM-Remote-Control
                Starting node helper for: MMM-Remote-Control
                Connecting socket for: MMM-SystemStats
                Starting module: newsfeed
                Connecting socket for: MMM-MyCommute
                ====================== Starting node_helper for module [MMM-MyCommute]
                Connecting socket for: MMM-GoogleMapsTraffic
                Starting node_helper for module: MMM-GoogleMapsTraffic
                Connecting socket for: MMM-DarkSkyForecast
                ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                Connecting socket for: MMM-MyCalendar
                Starting node helper for: MMM-MyCalendar
                { Error: listen EADDRINUSE 0.0.0.0:8080
                    at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                    at listenInCluster (net.js:1378:12)
                    at doListen (net.js:1492:7)
                    at process._tickCallback (internal/process/next_tick.js:63:19)
                    at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
                    at startup (internal/bootstrap/node.js:241:19)
                    at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
                  errno: 'EADDRINUSE',
                  code: 'EADDRINUSE',
                  syscall: 'listen',
                  address: '0.0.0.0',
                  port: 8080 }
                Launching application.
                  sdetweil @CyruS1337
                  @CyruS1337 said in MMM-MyCommute:
                  already an instance running with pm2…
                  pm2 list
                  pm2 stop 0
                  pm2 start 0
                  CyruS1337C 1 Reply Last reply Reply Quote 0
                    CyruS1337 Project Sponsor @sdetweil
                    pm2 list
                    pm2 stop 0
                    pm2 start 0
                    I did, unfortunately it still does not show me the module
                    pi@raspberrypi3:~/MagicMirror/modules/MMM-MyCommute $ pm2 list
                    │ Name │ id │ mode │ status │ ↺ │ cpu │ memory   │
                    │ mm   │ 0  │ fork │ online │ 5 │ 0%  │ 2.6 MB   │
                     Use `pm2 show <id|name>` to get more details about an app
                    pi@raspberrypi3:~/MagicMirror/modules/MMM-MyCommute $ pm2 stop 0
                    [PM2] Applying action stopProcessId on app [0](ids: 0)
                    [PM2] [mm](0) ✓
                    │ mm   │ 0  │ fork │ stopped │ 5 │ 0%  │ 0 B    │
                    pi@raspberrypi3:~/MagicMirror/modules/MMM-MyCommute $ pm2 start 0
                    [PM2] Applying action restartProcessId on app [0](ids: 0)
                    [PM2] [mm](0) ✓
                    [PM2] Process successfully started
                      sdetweil
                      ok, and pm2 logs to show the logging output
                        The module once worked on the PI. Do I have to do something now @sdetweil?
                        • 1 / 3
