    MMM-MyCommute
    22 Posts 4 Posters 8.6k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      Good Morning
      I have the module MMM-MyCommute installed on my 3 PIs. It also works on two out of three PIs. I do not know that the module works better on the second PI. I have already made the settings for a PI that runs MMM-MyCommute properly. Unfortunately, it does not work on the PI. Can someone help me please, that would be my configuration:
        module: 'MMM-MyCommute',
        position: 'top_left',
          apikey: 'API_KEY',
          origin: 'start',
          startTime: '04:00',
          endTime: '08:00',
      	travelTimeFormat: 'h[h]:m[min]',
      	colorCodeTravelTime: true,
      	showSummary: true,
          hideDays: [0,6],
          destinations: [
              destination: 'destination',
              label: 'Lisa Arbeit über Autobahn',
      		alternatives: true,
      		startTime: '05:00',
      		endTime: '08:00',
              label: 'Lisa Arbeit über Oensingen',
      		color: "#82BAE5",
      		waypoints: 'via:Oltenstrasse, 4702 Oensingen | via:Oltenstrasse, 4538 Oberbipp'
              label: 'Lisa Arbeit über Kestenholz',
      		startTime: '05:00',
      		waypoints: 'via:Oensingerstrasse, 4703 Kestenholz'
      		color: "#DB7093",
      		waypoints: 'via:Wangenstrasse, 4913 Bannwil'
        no ideas? Or can I do something that can help you to find the mistake?
          sdetweil @CyruS1337
          @CyruS1337 what does ‘does not run’ mean?
          did u open the developers console and look for any errors reported?
            If I access the MagicMirror directly via Putty do I have to enter npm start dev or how?
              sdetweil @CyruS1337
              @CyruS1337 yes, do
              export DISPLAY=:0
              npm start dev
                @sdetweil said in MMM-MyCommute:
                export DISPLAY=:0
                That comes out when I enter npm start dev
                > magicmirror@2.8.0 start /home/pi/MagicMirror
                > sh run-start.sh "dev"
                Starting MagicMirror: v2.8.0
                Loading config ...
                Loading module helpers ...
                Module helper loaded: MMM-WatchDog
                Module helper loaded: MMM-Remote-Control
                Module helper loaded: MMM-SystemStats
                Module helper loaded: MMM-MyCommute
                Module helper loaded: MMM-GoogleMapsTraffic
                Module helper loaded: MMM-DarkSkyForecast
                Module helper loaded: MMM-MyCalendar
                All module helpers loaded.
                Server started ...
                Connecting socket for: MMM-WatchDog
                Starting module helper: MMM-WatchDog
                Connecting socket for: MMM-Remote-Control
                Starting node helper for: MMM-Remote-Control
                Connecting socket for: MMM-SystemStats
                Starting module: newsfeed
                Connecting socket for: MMM-MyCommute
                ====================== Starting node_helper for module [MMM-MyCommute]
                Connecting socket for: MMM-GoogleMapsTraffic
                Starting node_helper for module: MMM-GoogleMapsTraffic
                Connecting socket for: MMM-DarkSkyForecast
                ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                Connecting socket for: MMM-MyCalendar
                Starting node helper for: MMM-MyCalendar
                { Error: listen EADDRINUSE 0.0.0.0:8080
                    at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                    at listenInCluster (net.js:1378:12)
                    at doListen (net.js:1492:7)
                    at process._tickCallback (internal/process/next_tick.js:63:19)
                    at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
                    at startup (internal/bootstrap/node.js:241:19)
                    at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
                  errno: 'EADDRINUSE',
                  code: 'EADDRINUSE',
                  syscall: 'listen',
                  address: '0.0.0.0',
                  port: 8080 }
                Launching application.
                  sdetweil @CyruS1337
                  @CyruS1337 said in MMM-MyCommute:
                  already an instance running with pm2…
                  pm2 list
                  pm2 stop 0
                  pm2 start 0
                  CyruS1337C 1 Reply Last reply Reply Quote 0
                    CyruS1337 Project Sponsor @sdetweil
                    pm2 list
                    pm2 stop 0
                    pm2 start 0
                    I did, unfortunately it still does not show me the module
                    pi@raspberrypi3:~/MagicMirror/modules/MMM-MyCommute $ pm2 list
                    │ Name │ id │ mode │ status │ ↺ │ cpu │ memory   │
                    │ mm   │ 0  │ fork │ online │ 5 │ 0%  │ 2.6 MB   │
                     Use `pm2 show <id|name>` to get more details about an app
                    pi@raspberrypi3:~/MagicMirror/modules/MMM-MyCommute $ pm2 stop 0
                    [PM2] Applying action stopProcessId on app [0](ids: 0)
                    [PM2] [mm](0) ✓
                    │ mm   │ 0  │ fork │ stopped │ 5 │ 0%  │ 0 B    │
                    pi@raspberrypi3:~/MagicMirror/modules/MMM-MyCommute $ pm2 start 0
                    [PM2] Applying action restartProcessId on app [0](ids: 0)
                    [PM2] [mm](0) ✓
                    [PM2] Process successfully started
                      ok, and pm2 logs to show the logging output
                        The module once worked on the PI. Do I have to do something now @sdetweil?
                          sdetweil @CyruS1337
                          @CyruS1337 i don’t know anything about the module… so just looking for debugging info…
                          pm2 logs should show something
                            That would be my logs
                            pi@raspberrypi3:~ $ pm2 logs
                            [TAILING] Tailing last 15 lines for [all] processes (change the value with --lin        es option)
                            /home/pi/.pm2/pm2.log last 15 lines:
                            PM2        | [2019-09-07T14:54:17.446Z] PM2 log: Stopping app:mm id:0
                            PM2        | [2019-09-07T14:54:17.944Z] PM2 log: pid=17526 msg=failed to kill -        retrying in 100ms
                            PM2        | [2019-09-07T14:54:18.048Z] PM2 log: pid=17526 msg=failed to kill -        retrying in 100ms
                            PM2        | [2019-09-07T14:54:18.145Z] PM2 log: pid=17526 msg=failed to kill -        retrying in 100ms
                            PM2        | [2019-09-07T14:54:18.224Z] PM2 log: App [mm] with id [0] and pid [1        7526], exited with code [0] via signal [SIGINT]
                            PM2        | [2019-09-07T14:54:18.245Z] PM2 log: pid=17526 msg=process killed
                            PM2        | [2019-09-07T14:54:27.372Z] PM2 log: Starting execution sequence in        -fork mode- for app name:mm id:0
                            PM2        | [2019-09-07T14:54:27.383Z] PM2 log: App name:mm id:0 online
                            PM2        | [2019-09-07T15:18:47.949Z] PM2 log: Process 0 in a stopped status,        starting it
                            PM2        | [2019-09-07T15:18:47.954Z] PM2 log: Stopping app:mm id:0
                            PM2        | [2019-09-07T15:18:48.369Z] PM2 log: pid=597 msg=failed to kill - re        trying in 100ms
                            PM2        | [2019-09-07T15:18:48.372Z] PM2 log: App [mm] with id [0] and pid [5        97], exited with code [0] via signal [SIGINT]
                            PM2        | [2019-09-07T15:18:48.469Z] PM2 log: pid=597 msg=process killed
                            PM2        | [2019-09-07T15:18:48.473Z] PM2 log: Starting execution sequence in        -fork mode- for app name:mm id:0
                            PM2        | [2019-09-07T15:18:48.493Z] PM2 log: App name:mm id:0 online
                            0|mm       | MESA-LOADER: failed to retrieve device information
                            0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by        environment.
                            0|mm       | libGL error: MESA-LOADER: failed to retrieve device information
                            0|mm       | Connecting socket for: MMM-MyCommute
                            0|mm       | ====================== Starting node_helper for module [MMM-MyCommu        te]
                            0|mm       | Connecting socket for: MMM-GoogleMapsTraffic
                            0|mm       | Starting node_helper for module: MMM-GoogleMapsTraffic
                            0|mm       | Connecting socket for: MMM-DarkSkyForecast
                            0|mm       | ====================== Starting node_helper for module [MMM-DarkSky        Forecast]
                            0|mm       | Connecting socket for: MMM-MyCalendar
                            0|mm       | Starting node helper for: MMM-MyCalendar
                            0|mm       | Sockets connected & modules started ...
                            0|mm       | Launching application.
                            0|mm       | Create new news fetcher for url: https://api.20min.ch/rss/view/1 -        Interval: 300000
                            0|mm       | WatchDog started. Maximum timeout: 10s.
                            0|mm       | Create new news fetcher for url: https://api.20min.ch/rss/view/67 -        Interval: 300000
                            0|mm       | Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-        GET payload:  { style: 'standard' }
                            0|mm       | Create new calendar fetcher for url: https://calendar.google.com/ca        lendar/ical/XXXXX%40gmail.com/private-b6dbd8fd617ffcffc29ab3478af2b6f1/b        asic.ics - Interval: 300000
                              sdetweil @CyruS1337
                              @CyruS1337 refresh the logs output… (watch out, your email private url is shown)
                                pi@raspberrypi3:~ $ pm2 reloadLogs
                                Reloading all logs...
                                All logs reloaded
                                PM2        | [2019-09-07T14:54:18.224Z] PM2 log: App [mm] with id [0] and pid [17526], exited with code [0] via signal [SIGINT]
                                PM2        | [2019-09-07T15:18:48.369Z] PM2 log: pid=597 msg=failed to kill - retrying in 100ms
                                PM2        | [2019-09-07T15:18:48.372Z] PM2 log: App [mm] with id [0] and pid [597], exited with code [0] via signal [SIGINT]
                                PM2        | [2019-09-07T16:10:56.689Z] PM2 log: Reloading logs...
                                PM2        | [2019-09-07T16:10:56.693Z] PM2 log: Reloading logs for process id 0
                                0|mm       | ====================== Starting node_helper for module [MMM-MyCommute]
                                0|mm       | ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                                0|mm       | Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
                                0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXXXXXXX%40gmail.com/private-b6dbd8fd617ffcffc29ab3478af2b6f1/basic.ics - Interval: 300000
                                  sdetweil @CyruS1337
                                  @CyruS1337 got to be more than that
                                    Here are the logs from /home/pi/.pm2/logs/mm-out.log
                                    > sh run-start.sh
                                    Loading config ...
                                    Server started ...
                                    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXXXX%40gmail.com/private-b6dbd8fd617ffcffc29ab3478af2b6f1/basic.ics - Interval: 300000
                                    And here are the logs from /home/pi/.pm2/logs/mm-error.log
                                      mieserwicht
                                      I had a similar problem. Just tried out some module configurations and forks.
                                      I now use MMM-GoogleMapsTraffic from here https://github.com/sdetweil/MMM-GoogleMapsTraffic.git (see this thread MMM-GoogleMapsTraffic freezes Magic Mirror)
                                      and MMM-MyCommute from here https://github.com/qistoph/MMM-MyCommute.git
                                      This seems to work for me.
                                      There is also a small error in your configuration. The first destination has a comma after the last configuration endTime. This needs to be removed for a propor JSON file.
                                      Regards Dirk
                                        So you suggest that I delete the module and download the specified links as “git”?
                                        And sorry for the late reply. Lately there was a lot going on (baby, house building, etc.)
                                          sdetweil @CyruS1337
                                          @CyruS1337 there is a bug in the googlemapstraffic module, I have a fixed version… you can rename the current module folder out of the way, and then git clone the fixed one from my repo.
                                            Hi @sdetweil
                                            Mhmmm sorry if I ask so stupid. How do I do that then I download the module from you …
