    MMM-MyCommute
    22 Posts 4 Posters 8.6k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      If I access the MagicMirror directly via Putty do I have to enter npm start dev or how?
        sdetweil @CyruS1337
        @CyruS1337 yes, do
        export DISPLAY=:0
        npm start dev
          @sdetweil said in MMM-MyCommute:
          export DISPLAY=:0
          That comes out when I enter npm start dev
          > magicmirror@2.8.0 start /home/pi/MagicMirror
          > sh run-start.sh "dev"
          Starting MagicMirror: v2.8.0
          Loading config ...
          Loading module helpers ...
          Module helper loaded: MMM-WatchDog
          Module helper loaded: MMM-Remote-Control
          Module helper loaded: MMM-SystemStats
          Module helper loaded: MMM-MyCommute
          Module helper loaded: MMM-GoogleMapsTraffic
          Module helper loaded: MMM-DarkSkyForecast
          Module helper loaded: MMM-MyCalendar
          All module helpers loaded.
          Server started ...
          Connecting socket for: MMM-WatchDog
          Starting module helper: MMM-WatchDog
          Connecting socket for: MMM-Remote-Control
          Starting node helper for: MMM-Remote-Control
          Connecting socket for: MMM-SystemStats
          Starting module: newsfeed
          Connecting socket for: MMM-MyCommute
          ====================== Starting node_helper for module [MMM-MyCommute]
          Connecting socket for: MMM-GoogleMapsTraffic
          Starting node_helper for module: MMM-GoogleMapsTraffic
          Connecting socket for: MMM-DarkSkyForecast
          ====================== Starting node_helper for module [MMM-DarkSkyForecast]
          Connecting socket for: MMM-MyCalendar
          Starting node helper for: MMM-MyCalendar
          { Error: listen EADDRINUSE 0.0.0.0:8080
              at Server.setupListenHandle [as _listen2] (net.js:1330:14)
              at listenInCluster (net.js:1378:12)
              at doListen (net.js:1492:7)
              at process._tickCallback (internal/process/next_tick.js:63:19)
              at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
              at startup (internal/bootstrap/node.js:241:19)
              at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
            errno: 'EADDRINUSE',
            code: 'EADDRINUSE',
            syscall: 'listen',
            address: '0.0.0.0',
            port: 8080 }
          Launching application.
            sdetweil @CyruS1337
            @CyruS1337 said in MMM-MyCommute:
            already an instance running with pm2…
            pm2 list
            pm2 stop 0
            pm2 start 0
            CyruS1337C 1 Reply Last reply Reply Quote 0
              CyruS1337 Project Sponsor @sdetweil
              pm2 list
              pm2 stop 0
              pm2 start 0
              I did, unfortunately it still does not show me the module
              pi@raspberrypi3:~/MagicMirror/modules/MMM-MyCommute $ pm2 list
              │ Name │ id │ mode │ status │ ↺ │ cpu │ memory   │
              │ mm   │ 0  │ fork │ online │ 5 │ 0%  │ 2.6 MB   │
               Use `pm2 show <id|name>` to get more details about an app
              pi@raspberrypi3:~/MagicMirror/modules/MMM-MyCommute $ pm2 stop 0
              [PM2] Applying action stopProcessId on app [0](ids: 0)
              [PM2] [mm](0) ✓
              │ mm   │ 0  │ fork │ stopped │ 5 │ 0%  │ 0 B    │
              pi@raspberrypi3:~/MagicMirror/modules/MMM-MyCommute $ pm2 start 0
              [PM2] Applying action restartProcessId on app [0](ids: 0)
              [PM2] [mm](0) ✓
              [PM2] Process successfully started
                ok, and pm2 logs to show the logging output
                  The module once worked on the PI. Do I have to do something now @sdetweil?
                    sdetweil @CyruS1337
                    @CyruS1337 i don’t know anything about the module… so just looking for debugging info…
                    pm2 logs should show something
                      That would be my logs
                      pi@raspberrypi3:~ $ pm2 logs
                      [TAILING] Tailing last 15 lines for [all] processes (change the value with --lin        es option)
                      /home/pi/.pm2/pm2.log last 15 lines:
                      PM2        | [2019-09-07T14:54:17.446Z] PM2 log: Stopping app:mm id:0
                      PM2        | [2019-09-07T14:54:17.944Z] PM2 log: pid=17526 msg=failed to kill -        retrying in 100ms
                      PM2        | [2019-09-07T14:54:18.048Z] PM2 log: pid=17526 msg=failed to kill -        retrying in 100ms
                      PM2        | [2019-09-07T14:54:18.145Z] PM2 log: pid=17526 msg=failed to kill -        retrying in 100ms
                      PM2        | [2019-09-07T14:54:18.224Z] PM2 log: App [mm] with id [0] and pid [1        7526], exited with code [0] via signal [SIGINT]
                      PM2        | [2019-09-07T14:54:18.245Z] PM2 log: pid=17526 msg=process killed
                      PM2        | [2019-09-07T14:54:27.372Z] PM2 log: Starting execution sequence in        -fork mode- for app name:mm id:0
                      PM2        | [2019-09-07T14:54:27.383Z] PM2 log: App name:mm id:0 online
                      PM2        | [2019-09-07T15:18:47.949Z] PM2 log: Process 0 in a stopped status,        starting it
                      PM2        | [2019-09-07T15:18:47.954Z] PM2 log: Stopping app:mm id:0
                      PM2        | [2019-09-07T15:18:48.369Z] PM2 log: pid=597 msg=failed to kill - re        trying in 100ms
                      PM2        | [2019-09-07T15:18:48.372Z] PM2 log: App [mm] with id [0] and pid [5        97], exited with code [0] via signal [SIGINT]
                      PM2        | [2019-09-07T15:18:48.469Z] PM2 log: pid=597 msg=process killed
                      PM2        | [2019-09-07T15:18:48.473Z] PM2 log: Starting execution sequence in        -fork mode- for app name:mm id:0
                      PM2        | [2019-09-07T15:18:48.493Z] PM2 log: App name:mm id:0 online
                      0|mm       | MESA-LOADER: failed to retrieve device information
                      0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by        environment.
                      0|mm       | libGL error: MESA-LOADER: failed to retrieve device information
                      0|mm       | Connecting socket for: MMM-MyCommute
                      0|mm       | ====================== Starting node_helper for module [MMM-MyCommu        te]
                      0|mm       | Connecting socket for: MMM-GoogleMapsTraffic
                      0|mm       | Starting node_helper for module: MMM-GoogleMapsTraffic
                      0|mm       | Connecting socket for: MMM-DarkSkyForecast
                      0|mm       | ====================== Starting node_helper for module [MMM-DarkSky        Forecast]
                      0|mm       | Connecting socket for: MMM-MyCalendar
                      0|mm       | Starting node helper for: MMM-MyCalendar
                      0|mm       | Sockets connected & modules started ...
                      0|mm       | Launching application.
                      0|mm       | Create new news fetcher for url: https://api.20min.ch/rss/view/1 -        Interval: 300000
                      0|mm       | WatchDog started. Maximum timeout: 10s.
                      0|mm       | Create new news fetcher for url: https://api.20min.ch/rss/view/67 -        Interval: 300000
                      0|mm       | Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-        GET payload:  { style: 'standard' }
                      0|mm       | Create new calendar fetcher for url: https://calendar.google.com/ca        lendar/ical/XXXXX%40gmail.com/private-b6dbd8fd617ffcffc29ab3478af2b6f1/b        asic.ics - Interval: 300000
                        sdetweil @CyruS1337
                        @CyruS1337 refresh the logs output… (watch out, your email private url is shown)
                          pi@raspberrypi3:~ $ pm2 reloadLogs
                          Reloading all logs...
                          All logs reloaded
                          PM2        | [2019-09-07T14:54:18.224Z] PM2 log: App [mm] with id [0] and pid [17526], exited with code [0] via signal [SIGINT]
                          PM2        | [2019-09-07T15:18:48.369Z] PM2 log: pid=597 msg=failed to kill - retrying in 100ms
                          PM2        | [2019-09-07T15:18:48.372Z] PM2 log: App [mm] with id [0] and pid [597], exited with code [0] via signal [SIGINT]
                          PM2        | [2019-09-07T16:10:56.689Z] PM2 log: Reloading logs...
                          PM2        | [2019-09-07T16:10:56.693Z] PM2 log: Reloading logs for process id 0
                          0|mm       | ====================== Starting node_helper for module [MMM-MyCommute]
                          0|mm       | ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                          0|mm       | Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
                          0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXXXXXXX%40gmail.com/private-b6dbd8fd617ffcffc29ab3478af2b6f1/basic.ics - Interval: 300000
                            sdetweil @CyruS1337
                            @CyruS1337 got to be more than that
                              Here are the logs from /home/pi/.pm2/logs/mm-out.log
                              > sh run-start.sh
                              Loading config ...
                              Server started ...
                              Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXXXX%40gmail.com/private-b6dbd8fd617ffcffc29ab3478af2b6f1/basic.ics - Interval: 300000
                              And here are the logs from /home/pi/.pm2/logs/mm-error.log
                                mieserwicht
                                I had a similar problem. Just tried out some module configurations and forks.
                                I now use MMM-GoogleMapsTraffic from here https://github.com/sdetweil/MMM-GoogleMapsTraffic.git (see this thread MMM-GoogleMapsTraffic freezes Magic Mirror)
                                and MMM-MyCommute from here https://github.com/qistoph/MMM-MyCommute.git
                                This seems to work for me.
                                There is also a small error in your configuration. The first destination has a comma after the last configuration endTime. This needs to be removed for a propor JSON file.
                                Regards Dirk
                                  So you suggest that I delete the module and download the specified links as “git”?
                                  And sorry for the late reply. Lately there was a lot going on (baby, house building, etc.)
                                    sdetweil @CyruS1337
                                    @CyruS1337 there is a bug in the googlemapstraffic module, I have a fixed version… you can rename the current module folder out of the way, and then git clone the fixed one from my repo.
                                      Hi @sdetweil
                                      Mhmmm sorry if I ask so stupid. How do I do that then I download the module from you …
                                        sdetweil @CyruS1337
                                        @CyruS1337 https://github.com/sdetweil/MMM-GoogleMapsTraffic.git from the post a few back
                                        • F Offline
                                          fribse
                                          Sorry for replying in an old thread, but you wrote apikey in the config, it should be apiKey
