    MMM-Alexaonoff can’t find devices
    26 Posts 2 Posters 10.4k Views 2 Watching
      sdetweil @Stoffbeuteluwe
      @Stoffbeuteluwe so, can u go to one device and get its IP address somehow? so we can see if its on the same network address range…
      also wonder if the code works on Mac… open the developers window and look at the console…
      but u said it worked once…
      maybe you can look in your router dhcp clients page
        sdetweil
        i can’t get alexa to discover any of virtual wemo devices
        StoffbeuteluweS 2 Replies Last reply Reply Quote 0
        • StoffbeuteluweS Offline
          Stoffbeuteluwe Project Sponsor @sdetweil
          @sdetweil maybe Alexa problem
            21901
            21902
            21903
            21904
            21905
            21906
            21907
            21908
            21909
            21910
            21911
            21912
            21913
            21914
            21915
            21916
            21917
            21918
            21919
            21920
            21921
            21922
            21923
            21924
            21925
            21926
            21927
            21928
            21929
            21930
            21931
            21932
            21933
            21934
            21935
            21936
            21937
            21938
            21939
            21940
            21941
             discoveryService not running +0ms
            FauxMo service started. Listening on 192.168.178.35:21900-21941
             discoveryService binding to port 1900 for ssdp discovery +2ms
             discoveryService server listening 0.0.0.0:1900 +164ms
             deviceEndpoints Setup Server running. +9ms
            do you know what that means?
              @Stoffbeuteluwe said in MMM-Alexaonoff can’t find devices:
              means the code in the module has setup to listen on a number of known ports that the Wemo plugs use for discovery by the alexa plugin.
              when alexa does home automation device discovery, it sends a broadcast message ('is anyone there?) to anything listening on those ports, and whatever is listening will respond with a predefined response (‘yes, I am here’)…
              the discovery code for wemo plugs was built into alexa early code… but seems that Alexa has removed that code and expects a plugin to do the work… (My opinion)
              a google search on ‘wemo app not finding devices’ produces a lot of info. I could never get alexa to discover my mirrors
                @sdetweil ok thank you for your help…
