    oversized fonts and mixed modules
    7 Posts 2 Posters 1.8k Views 2 Watching
    • P Offline
      papinel
      Hello
      I just installed in my MM, 7 modules
      Clock --------------------------- top left
      mmm-images photos -------- full center which turns in loop in bottom of stain
      mmm-mail --------------------- bottom left
      compliment ------------------- center
      current weather -------------- top left
      water forecast ----------------- center left
      newfeed ------------------------ at the bottom
      My first problem that happens to me is that all my modules are not quite in their place
      My second problem is that fonts are too big
      While browsing the forum I understood that it would be necessary to modify variables in custom css
      But then it’s me who has a problem I went to the forum https://forum.magicmirror.builders/topic/10831/7-touchscreen-module-size-and-overlapping-issues/2 and I read with a translator the different solution but it’s really hard to work and understand, I’m French and do not speak English so if you could give me very detailed advice it would be great, I would try to understand with the translator I I’ll try to put a picture so you can see
      Thanks for your help
      papinel
      • P Offline
        papinel
        @papinel said in oversized fonts and mixed modules:
        sorry I made a mistake
        current weather -------------- top right
        water forecast ----------------- center right
        • lavolp3L Offline
          lavolp3 Module Developer
          I would assume that your resolution is not the native resolution of the monitor. You would then find as well the font of the starting console at the start of the raspberry pi too big.
          However you could try to use a “zoom” factor in your config.js
          language: 'de',
          timeFormat: 24,
          units: 'metric',
          zoom: 0.5,
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • P Offline
            papinel
            language: ‘from’,
            timeFormat: 24,
            units: ‘metric’,
            zoom: 0.5,
            Thank you but how to install these 4 lines and I place or in my config there is no accollade {}? and in language I replace ‘de’ with ‘fr’?
            • lavolp3L Offline
              lavolp3 Module Developer @papinel
              @papinel You need to put the “zoom: 0.8” line into your config.js.
              Just do a
              sudo nano ~/MagicMirror/config/config.js
              and write the line below the language or timeformat line. Don’t forget the comma!
              Close and save it and restart.
              Out of curiosity: What is the resolution of your system currently?
              Did you put something specific into the /boot/config.txt of your raspberry pi? Or do you have some other device?
              • P Offline
                papinel
                Hello
                and full of thanks for the 2 very detailed tips you gave me,
                actually after changing the resolution in raspberry and add
                zoom: 0.5,
                in my config everything is perfect attached here the photo
                thanks again
                could i ask you another question that has nothing to do with custom css
                papinel
                • P Offline
                  papinel
                  RESOLVED
