    config.js in JSON format
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    17 Posts 4 Posters 6.8k Views 4 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      I think I understand (and like!) what you are trying to do, but the downside is that you’re going to create one hell of a file. The module configs are in a lot of cases much bigger than what the module creator suggests users to change. The clock you’ve shown is a very good example.
      However, it might lead to a very promising function, so I’d be happy to support.
      I would very much like to see the web interface to be limited to layers with a drop-down function
      First layer: all installed modules.
      Click on a module -> open dropdown with all config parameters for this module.
      (Somehow) limit the possibilities to change config options to prevent semantic errors. E.g. for boolean parameters, the user should only be able to switch between true and false. String parameters should be converted to strings automatically. Numbers be parsed to number and so on…
      If you create a web interface that gives the user the possibility to easily change config options AND that prevents semantic errors (e.g. by checking the new input instantly).
      …then you’re the hero!!
      The more I write about it the more I like it…
      Is there somethin on github that I can have a look at already?
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      SergeS 2 Replies Last reply Reply Quote 0
        sdetweil
        another mirror runtime uses jsonform, and a schema file provided by
        each module (exposing what the module wants configurable, and how), and then generates a web UI for all the info, provides a save function, which updates its config file and then restarts the app.
        I have created modules using this capability and also extended it on the base to allow module location placement (like mm position ) via dropdown selection.
        SergeS 1 Reply Last reply Reply Quote 0
        • SergeS Offline
          Serge @lavolp3
          @lavolp3 said in config.js in JSON format:
          All other modules have + - the same number of parameters. config.js looks good and readable.
          Changes of module parameters do not affect functionality. They change appearence so if all parameters are inputed correctly (e.g. numbers to numbers, strings to strings) - everything will work fine.
          I have some draft of the interface and it looks similar to those you have described. However, I drop off the idea of dropdowns - due to the huge amount of settings for each module. I have made a left side menu with buttons for each module: e.g. clock, calendar, weather, etc. Some current screenshot is attached.
          screen
          Screenshot from mobile phone:
          photo-2019-09-13-15-20-50
          Not yet. Its a local development at this stage.
          @sdetweil said in config.js in JSON format:
          I have created modules using this capability.
          do you have your development available somewhere to look over?
          • SergeS Offline
            Serge @sdetweil
            This post is deleted!
              sdetweil @Serge
              @Serge remember, this is not MagicMirror…
              here is the mirror code
              https://github.com/evancohen/smart-mirror
              here is a module (plugin) for smart-mirror
              https://github.com/sdetweil/backgroundImage
              here is a sample plugin
              https://github.com/sdetweil/samplePlugin
              in the base mirror code, YOU have to edit the index.html to add
              the appropriate lines to enable your plugin
              • SergeS Offline
                Serge @sdetweil
                I have looked throught all the code. For simplicity I will call “SmartMirror” as SM and MagicMirror as MM further.
                1. config.schema.json files in SM contain plugins’ parameters and these files have JSON format. Example is a calendar config file smart-mirror/plugins/calendar/config.schema.json
                    "schema": {
                        "calendar": {
                            "type": "object",
                            "title": "Calendar Settings",
                            "properties": {
                                "icals": {
                                    "type": "array",
                                    "title": "iCal URLs",
                                    "items": {
                                        "type": "string"
                                "maxResults": {
                                    "type": "integer",
                                    "title": "Max Number of Events for all iCals",
                                    "default": 9
                1. config.js in MagicMirror is not made in JSON format so it is not easy to make changes there as compared to SM’s config.schema.json
                var config = {
                	address: "localhost",
                	port: 8080,
                	ipWhitelist: [],
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "New York Times",
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                Maybe I think wrong, please correct me if so.
                  sdetweil @Serge
                  @Serge maybe javascript-stringify npm module would help.
                  Load config.js
                  Json stringify
                  Apply schemas
                  Capture json on save
                  Convert to js
                  this little script seems to work
                  var jjs=require('javascript-stringify')
                  var cfg=require('../MagicMirror/config/config.js')
                  var js=require('json-stringify')
                  var js_config = JSON.stringify(cfg.config)
                  console.log(cfg)
                  jjs_config=jjs.stringify(cfg,null,'\t')
                  console.log("var config="+jjs_config)
                  • ? Offline
                    A Former User
                    JSON converting may lose some js specific features like callback function, dynamic values by condition, etc. I doubt the benefit of strict json format.
                    And the user would still make mistakes to write strict JSON format.
                    I can’t agree JSON is the only or better way to make user-friendly configurable web UI.
                      sdetweil @Guest
                      @Sean do you have some examples of these kinds of data elements? I’d be interested to pass them thru this simple converter to see the fidelity
                      • ? Offline
                        A Former User @sdetweil
                        1. callback function as value;
                          Many of my modules use the callback functions to make user command or user-customizable dynamic features instead to modify the source itself. (eg. filter, sort, transform, …)
                          Here is the the sameple of MMM-NotificationTrigger;
                          module: "MMM-NotificationTrigger",
                            triggers:[
                                trigger: "SOME_NOTIFICATION",
                                fires: [
                                    fire:"SHOW_ALERT",
                                    payload: (payload) => {
                                      return {
                                        type:"notification",
                                        title:"Notification comming",
                                        message: payload.someOption
                        1. dynamic values;
                          I manage several different configurations in one config.js for my convenience. like this;
                        (simplified concept)
                        const mode = "testA"
                        const someValue = {
                          "testA" : "testA",
                          "testB" : "testB",
                          "debug" : "debug",
                          "release" : "release",
                          module: "MMM-SOMEMODULE",
                            someField: ((mode == "testA") ? true : false),
                            someField2: someValue[mode],
                        The real usage is more complex but you can catch my approach.
