    MMM-Ring: Displays a video stream of your Ring doorbell when someone rings your doorbell.
    38 Posts 9 Posters 19.7k Views 12 Watching
    • P Offline
      Peter Leemon
      out of curiosity what localized devices did you use and compatible with raspberry pi as well as MM?
        dc331903
        Heads Up! -“Ring enables mandatory two-factor authentication”
        Looks like 2FA is the new thing moving forward. I just started working on this module tonight and haven’t fully tested, but at least I know where to start now.
        I did notice that the sample code in the site for setting up 2FA is missing a comma in case you miss it. https://github.com/DustinBryant/MMM-Ring/wiki/Two-Factor-Auth-(ring2faRefreshToken-config-option)
          dc331903 @dc331903
          @dc331903 Trying the above for Two-factor auth has not worked for me still. Let us know if yours is working! Logging seems to show it is getting connected to camera though… so it could just be a positioning issue for me.
            DustinBryant
            Just updated this repository to require 2F Refresh Token as well as automating the process of automatically getting a new Refresh Token when the old one expires.
            In order to get this update navigate to the MMM-Ring directory within MagicMirror/modules and perform the following:
            git pull
            npm install
            If you need more information on the Refresh Token you can find it here: https://github.com/DustinBryant/MMM-Ring/wiki/Refresh-Tokens
            Also, I no longer have a Ring device so I can’t maintain the repository anymore. I’ll do my best with what I can but I’m definitely looking for someone to take this over.
            • N Offline
              Nicoh @DustinBryant
              @dustinbryant Hi there. I have a refresh token. It works nice. But now i dont get it on the Mirror. How i update the efreshtoken? please help me
                sdetweil @Nicoh
                @nicoh the doc says to see the wiki
                • N Offline
                  Nicoh
                  @sdetweil thanks. I do it and get the token. But If i Press the Ring Doorbell nothing happen.
                    sdetweil @Nicoh
                    @nicoh I do not know, sorry…
                    • 4 / 4
