    MMM-Ring: Displays a video stream of your Ring doorbell when someone rings your doorbell.
    43 Posts 11 Posters 25.5k Views 14 Watching
      sithlordhood
      Ok, thanks very much for helping out.
      One final thing that i thought of was that i’m using the wired ethernet interface on the Pi, not the WiFi. Not sure if this matters, just thought it a bit odd that i did not get any data displayed in the Network tab?
        sithlordhood
        Just to update - dont know whats changed but the module is working ok now! Thanks!
          Peter Leemon
          Hi all only a noob here would love to get my MM to show the RING video feed when someone rings the doorbell, but no idea how can anyone assist me in doing this please very much appreciated.
          Cheers
          Pete.
            Doudy
            @Peter
            It’s the same for me
            I have nothing in “Network”
            I have no “Public” directory !
            Help…
            When i do /MagicMirror $ npm start dev
            I have following :
            { Error: listen EADDRINUSE 127.0.0.1:8585
                at Object._errnoException (util.js:1024:11)
                at _exceptionWithHostPort (util.js:1046:20)
                at Server.setupListenHandle [as _listen2] (net.js:1351:14)
                at listenInCluster (net.js:1392:12)
                at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
                at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
              code: 'EADDRINUSE',
              errno: 'EADDRINUSE',
              syscall: 'listen',
              address: '127.0.0.1',
              port: 8585 }
              Peter Leemon
              did you get yours to work?, I gave up at this stage
                Doudy @Peter Leemon
                @Peter-Leemon
                Still no video
                I don’t know if mmm-Ring works
                  DustinBryant
                  Unfortunately, I’ve since replaced my ring devices for something more localized. I do know recently Ring had an update that requires 2-factor authentication. You may want to try setting that up and following the directions on how to use it with mmm-ring.
                    Peter Leemon
                    out of curiosity what localized devices did you use and compatible with raspberry pi as well as MM?
                      dc331903
                      Heads Up! -“Ring enables mandatory two-factor authentication”
                      Looks like 2FA is the new thing moving forward. I just started working on this module tonight and haven’t fully tested, but at least I know where to start now.
                      I did notice that the sample code in the site for setting up 2FA is missing a comma in case you miss it. https://github.com/DustinBryant/MMM-Ring/wiki/Two-Factor-Auth-(ring2faRefreshToken-config-option)
                        dc331903 @dc331903
                        @dc331903 Trying the above for Two-factor auth has not worked for me still. Let us know if yours is working! Logging seems to show it is getting connected to camera though… so it could just be a positioning issue for me.
                          DustinBryant
                          Just updated this repository to require 2F Refresh Token as well as automating the process of automatically getting a new Refresh Token when the old one expires.
                          In order to get this update navigate to the MMM-Ring directory within MagicMirror/modules and perform the following:
                          git pull
                          npm install
                          If you need more information on the Refresh Token you can find it here: https://github.com/DustinBryant/MMM-Ring/wiki/Refresh-Tokens
                          Also, I no longer have a Ring device so I can’t maintain the repository anymore. I’ll do my best with what I can but I’m definitely looking for someone to take this over.
                          • N
                            Nicoh @DustinBryant
                            @dustinbryant Hi there. I have a refresh token. It works nice. But now i dont get it on the Mirror. How i update the efreshtoken? please help me
                              sdetweil @Nicoh
                              @nicoh the doc says to see the wiki
                              • N
                                Nicoh
                                @sdetweil thanks. I do it and get the token. But If i Press the Ring Doorbell nothing happen.
                                  sdetweil @Nicoh
                                  @nicoh I do not know, sorry…
                                  • E
                                    ewingfox @sdetweil
                                    @sdetweil I’ll move to a new thread depending on your response - I know this is an abandoned module, but do you know if it’s still working (anywhere) or do I need to start from scratch? The wife has submitted another ‘feature request’. I fear I have created a monster :D
                                    S plainbrokeP 2 Replies Last reply Reply Quote 0
                                      sdetweil @ewingfox
                                      @ewingfox this module uses ffmpeg , which was discontinued
                                      Feb 2025
                                      There are manual ways to get it
                                      The module install does not handle that.
                                      See https://www.itpathsolutions.com/ffmpegkit-shutdown-what-to-do-next
                                      • E
                                        ewingfox @sdetweil
                                        @sdetweil Thank you - I’ll do some research; I’ve also requested early access to the new ‘official’ Ring developer portal hosted on AWS. If you hear me talking about this again - it’ll be in a new thread (hopefully announcing a more supportable novel module!)
                                        • plainbrokeP
                                          plainbroke @DustinBryant
                                          @DustinBryant
                                          Could this be used with my WYZE Door Bell???
                                          Does it operate off the ip address or does it have to use the ring program.?
                                          • plainbrokeP
                                            plainbroke @ewingfox
                                            @ewingfox
                                            Let me know if you get it working…
                                            Sounds like something we would enjoy
                                            • 2 / 3
