    MMM-Ring: Displays a video stream of your Ring doorbell when someone rings your doorbell.
    43 Posts 11 Posters 24.1k Views 14 Watching
      DustinBryant
      Ok, run in dev mode again but switch over to the Network tab (instead of console) and see if any of the lines have red text prior or after hitting your doorbell again.
        sithlordhood
        i dont see any entries in the network tab at all, i have stopped and restarted the record and hit the button on the doorbell but nothing apears in the log.
          DustinBryant
          I’ve exhausted everything I can think of. Your working with an ideal situation where everything is updated and fresh and still not able to get the stream. For some reason the videos aren’t getting dropped in that public folder for you when the event gets activated. Based on what you’ve provided it should be working.
          Since I can’t recreate the condition on my end there’s not much I can do here. Your specific issue is the first I’ve seen or heard of. That layer of the module is utilizing the ring-api from dgreif which I have no contributions to.
          If you’re adventurous enough and have a little bit of coding background you may try downloading his api and play with the browser example he has to see if you can get that working.
          Sorry @sithlordhood !
            sithlordhood
            Ok, thanks very much for helping out.
            One final thing that i thought of was that i’m using the wired ethernet interface on the Pi, not the WiFi. Not sure if this matters, just thought it a bit odd that i did not get any data displayed in the Network tab?
              sithlordhood
              Just to update - dont know whats changed but the module is working ok now! Thanks!
              • P Offline
                Peter Leemon
                Hi all only a noob here would love to get my MM to show the RING video feed when someone rings the doorbell, but no idea how can anyone assist me in doing this please very much appreciated.
                Cheers
                Pete.
                  Doudy
                  @Peter
                  It’s the same for me
                  I have nothing in “Network”
                  I have no “Public” directory !
                  Help…
                  When i do /MagicMirror $ npm start dev
                  I have following :
                  { Error: listen EADDRINUSE 127.0.0.1:8585
                      at Object._errnoException (util.js:1024:11)
                      at _exceptionWithHostPort (util.js:1046:20)
                      at Server.setupListenHandle [as _listen2] (net.js:1351:14)
                      at listenInCluster (net.js:1392:12)
                      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
                      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
                    code: 'EADDRINUSE',
                    errno: 'EADDRINUSE',
                    syscall: 'listen',
                    address: '127.0.0.1',
                    port: 8585 }
                  • P Offline
                    Peter Leemon
                    did you get yours to work?, I gave up at this stage
                      Doudy @Peter Leemon
                      @Peter-Leemon
                      Still no video
                      I don’t know if mmm-Ring works
                        DustinBryant
                        Unfortunately, I’ve since replaced my ring devices for something more localized. I do know recently Ring had an update that requires 2-factor authentication. You may want to try setting that up and following the directions on how to use it with mmm-ring.
                        • P Offline
                          Peter Leemon
                          out of curiosity what localized devices did you use and compatible with raspberry pi as well as MM?
                            dc331903
                            Heads Up! -“Ring enables mandatory two-factor authentication”
                            Looks like 2FA is the new thing moving forward. I just started working on this module tonight and haven’t fully tested, but at least I know where to start now.
                            I did notice that the sample code in the site for setting up 2FA is missing a comma in case you miss it. https://github.com/DustinBryant/MMM-Ring/wiki/Two-Factor-Auth-(ring2faRefreshToken-config-option)
                              dc331903 @dc331903
                              @dc331903 Trying the above for Two-factor auth has not worked for me still. Let us know if yours is working! Logging seems to show it is getting connected to camera though… so it could just be a positioning issue for me.
                                DustinBryant
                                Just updated this repository to require 2F Refresh Token as well as automating the process of automatically getting a new Refresh Token when the old one expires.
                                In order to get this update navigate to the MMM-Ring directory within MagicMirror/modules and perform the following:
                                git pull
                                npm install
                                If you need more information on the Refresh Token you can find it here: https://github.com/DustinBryant/MMM-Ring/wiki/Refresh-Tokens
                                Also, I no longer have a Ring device so I can’t maintain the repository anymore. I’ll do my best with what I can but I’m definitely looking for someone to take this over.
                                • N Offline
                                  Nicoh @DustinBryant
                                  @dustinbryant Hi there. I have a refresh token. It works nice. But now i dont get it on the Mirror. How i update the efreshtoken? please help me
                                    sdetweil @Nicoh
                                    @nicoh the doc says to see the wiki
                                    • N Offline
                                      Nicoh
                                      @sdetweil thanks. I do it and get the token. But If i Press the Ring Doorbell nothing happen.
                                        sdetweil @Nicoh
                                        @nicoh I do not know, sorry…
                                        • E Offline
                                          ewingfox @sdetweil
                                          @sdetweil I’ll move to a new thread depending on your response - I know this is an abandoned module, but do you know if it’s still working (anywhere) or do I need to start from scratch? The wife has submitted another ‘feature request’. I fear I have created a monster :D
                                          S plainbrokeP 2 Replies Last reply Reply Quote 0
                                            sdetweil @ewingfox
                                            @ewingfox this module uses ffmpeg , which was discontinued
                                            Feb 2025
                                            There are manual ways to get it
                                            The module install does not handle that.
                                            See https://www.itpathsolutions.com/ffmpegkit-shutdown-what-to-do-next
                                            • 2 / 3
