    Newbie if else question
    7 Posts 3 Posters 2.0k Views 3 Watching
    • F Offline
      frickinnuts
      I’m trying to use a stolen github script to display MMM-horoscope which works well. I just want to change the sign at different times. Like between 24:00 and 08:00 I want to display 'taurus" and ‘virgo’ after 8. tried if else but always get an error. I sure the syntax isn’t correct. Any if else gurus out there? If there another way?
      module: ‘MMM-horoscope’,
      position: ‘top_right’,
      sign: ‘virgo’,
        sdetweil @frickinnuts
        @frickinnuts tried if/else where?
        • F Offline
          frickinnuts
          This post is deleted!
          • F Offline
            frickinnuts
            if (hour < 8 ) {
            sign: ‘tarus’,
            } else {
            sign: ‘virgo’,
              @frickinnuts can’t do that in config.js. only in code.
              • F Offline
                frickinnuts
                Saddness :(
                  jasondreher
                  If you create two modules you could use MMM-ModuleScheduler to schedule the show/hide of one the modules. I have not used it but it appears to do what you are asking.
                  https://github.com/ianperrin/MMM-ModuleScheduler
                  I personally use MMM-Remote-Control, but to do this you need to send a http request to show/hide the module. I do this through Home Assistant.
                  https://github.com/Jopyth/MMM-Remote-Control
