    After adding MMM-GPIO-Notifications, config.js doesn't work...
    13 Posts 3 Posters 5.1k Views 3 Watching
    • T Offline
      tomXGames
      Hi!
      My config.js has an error in it and I’m not able to solve it. Here it is:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "de",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "Neue Zürcher Zeitung",
      						url: "https://www.nzz.ch/recent.rss"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
            			module: "MMM-CalendarExt",
              		system: {
                				show: ["daily"],
                				locale: 'de',
                				redrawInterval:60000,
              			views: {
                				daily: {
                  						position:'lower_third',
                  						counts:7,
              			defaultCalendar: {
                						maxEntries:50,
                						maxDays:180,
                						interval: 1000*60*5,
              			calendars :[
                  						url: "https://calendar.google.com/calendar/ical/tommaso.peduzzi%40gmx.ch/private-088063fff967db8474e57b3a7cdf176a/basic.ics",
      							profiles: ['Tom'],
                  						url: "https://www.ferienwiki.ch/exports/ferien/2019/ch/basel-stadt",
      							profiles: ['default'],
              		module: 'MMM-ProfileSwitcher',
                  module: "currentweather",
                    locationID: "6458763",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    appid: "123"
                  module: "weatherforecast",
                  header: "Weather Forecast",
                    appid: "123"
      			    module: 'MMM-GPIO-Notifications',
      			        '17': {
      			          gpio_state: 1,
      			          gpio_debounce: 10,
      			          notifications: [
      			              notification: "'CURRENT_PROFILE', 'Tom'",
      			              payload: { true }
      			              notification: 'SCREEN_ON',
      			              payload: { 'forced': false }
      			        '4': {
      			          gpio_state: 1,
      			          gpio_debounce: 20,
      			          notifications: [
      			              'notification': 'SCREEN_TOGGLE',
      			              'payload': { 'forced': true }
      Can anybody help me here?
      tomXGames
      S mumblebajM 3 Replies Last reply Reply Quote 0
        sdetweil @tomXGames
        @tomXGames run
        npm check:config
        Fix errors top down
        • T Offline
          tomXGames
          @sdetweil said in After adding MMM-GPIO-Notifications, config.js doesn't work...:
          npm check:config
          It says, that there is no such command… I’m running it in the MagicMirror directory…
            sdetweil @tomXGames
            @tomXGames sorry,
            npm config:check
            See list of npm enabled commands in package.json
            • T Offline
              tomXGames @sdetweil
              @sdetweil The command still doesn’t work and after adding a comma, nothing is even shown. What am i doing wrong?
                sdetweil @tomXGames
                @tomXGames you do this command in the MagicMirror folder
                • T Offline
                  tomXGames @sdetweil
                  @sdetweil Yeah that’s what I did
                  • mumblebajM Offline
                    mumblebaj Module Developer @tomXGames
                    @tomXGames THis certainly doesn’t look right:
                      sdetweil @tomXGames
                      @tomXGames what do u mean by doesn’t work?
                      Black screen could indicate another problem
                      Are u using pm2?
                      If so, pm2 logs to see what the output is.
                      Also, dev mode
                      pm2 stop 0
                      cd ~/MagicMirror
                      npm start dev
                        @tomXGames IF not mistaken, the “,” after the last module should not be there either.
                          sdetweil @tomXGames
                          @tomXGames so much fun…
                          so, looking thru the config…
                          I think u just have a syntax error
                          			        '17': {
                          			          gpio_state: 1,
                          			          gpio_debounce: 10,
                          			          notifications: [
                          					// see https://github.com/tosti007/MMM-ProfileSwitcher
                          					// Switching Profiles
                          					// this.sendNotification('CURRENT_PROFILE', 'DESIRED_PROFILE_NAME_HERE');
                          			              notification: 'CURRENT_PROFILE',
                          			              payload:  'Tom'
                          			        '4': {
                          			          gpio_state: 1,
                          			          gpio_debounce: 20,
                          			          notifications: [
                          at least this works for me
                          altho he left out an install step…
                          after git clone
                          cd MMM-GPIO-Notifications
                          npm install
                          • T Offline
                            tomXGames @sdetweil
                            Thanks for your help… I implemented your change and there’s no error anymore. But MMM-CalendarExt is not being shown, even though I put the class to “default everyone”. Do you have an idea, what I’m doing wrong here?
                              sdetweil @tomXGames
                              @tomXGames sorry, don’t know the module at all… just debugged why it didn’t load.
                              you could open the developers console and see if the notification is sent from the module as u expected
