    Mm on raspberry pi4
    4 Posts 2 Posters 1.1k Views 2 Watching
    • F
      florian
      I have tried to instal the mm on my raspberry pi4, but without succes. It says my node is not the correct version. I have a newer version. Does anyone know how to downgrade this or have an installing link for a mm with the newer version?
        sdetweil @florian
        @florian use my updated installer
        https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
        Rename MagicMirror folder out if the way
        • F
          florian @sdetweil
          Your first link or one that is mentioned later on?
            sdetweil @florian
            @florian the link here takes u to the topic (where u can read about WHY the updated installer) , which has the command to execute the installer…
