    Blank screen with error in terminal upon start.
    8 Posts 3 Posters 2.1k Views 3 Watching
      dcarls91
      Hello, I recently lost wifi on my pi and the magic mirror went down. I restarted and reconnected the pi to internet and went to start the magic mirror. I received a bunch of error messages in the command terminal something possibly to do with a module not found. I am unable to access logs for this. I have so far began with a fresh install of magic mirror which works flawlessly with the stock config.js file and default modules. I then added my old config file after running npm config:check with no errors found as well as added back all of my modules after updating and fixing anything found after running an audit. After doing this it is back to the error messages and blank black screen. Does anyone have any suggestions on where to start looking to attempt to fix this.
      -thanks in advance
        sdetweil @dcarls91
        @dcarls91 start the mirror with the developers window open
        npm start dev
        then use the mouse to select the tab labeled ‘console’ and scroll up…
        some piece of code (module_name.js) is having a fatal error, and the UI has died…
          dcarls91
          So I tired this and it tells me that the dev tools was disconnected from the page. I have also gone in and ran an audit and updated all packages. This is with a fresh install of Magic Mirror as well as all modules
          S lavolp3L 2 Replies Last reply Reply Quote 0
            sdetweil @dcarls91
            @dcarls91 if u added back modules, did u check and run npm install in the module folders where they had a package.json file?
            if you do npm start from a terminal window, you might get some error messages…
            I would go back to the base config.js and start adding one module at a time…
              dcarls91 @sdetweil
              @sdetweil I will do that. I went into all of my modules and and ran npm install as well
                dcarls91
                It may also be an electron issue
                • lavolp3L Offline
                  lavolp3 Module Developer @dcarls91
                  @dcarls91 I’m not sure if what you did was right.
                  For me the best way and proven a hundred times is:
                  • sit at an external device (laptop/PC)
                  • SSH into the mirror
                  • npm start dev
                  • open the mirror’s page on a browser on the laptop/PC (http://IP.OF.THE.MIRROR:8080)
                  • check the shell console (where you did the npm start dev) as well as the developer’s console of the browser for errors.
                  There will be something that will help you find the error
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                    sdetweil @dcarls91
                    @dcarls91 said in Blank screen with error in terminal upon start.:
                    IF they do NOT have a package.json file as part of a module, then there is a bad side effect or a required file beging deleted
                    you can check
                    cd ~/MagicMirror
                    ls modules/node_modules/node_helper/index.js
                    if the file is there, all good,
                    if not do this
                    cd ~/MagicMirror
                    git checkout modules/node_modules/node_helper/index.js
