    Update to v2.9.0 fail
    48 Posts 3 Posters 21.6k Views 3 Watching
      bdream
      @sdetweil said in Update to v2.9.0 fail:
      that is all u had, so you would have selected n, instead of y
      Sorry, is this I have to run script again and select n instead of yes?
      cheers, bdream
        sdetweil @bdream
        @bdream if you have edited the package-lock.json file
          bdream
          reedited and run script
          pi@MagicMirror:~/MagicMirror $  bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
          doing test run = false
          update log will be in /home/pi/MagicMirror/installers/upgrade.log
          saving custom.css
          upgrading from version 2.9.0 to 2.9.0
          fetching latest revisions
          there are 2 local files that are different than the master repo
             package-lock.json
             vendor/package-lock.json
          any *-lock.json files do not need to be saved
          do you want to save these files for later   (Y/n)?n
          updating MagicMirror runtime, please wait
          > magicmirror@2.9.0 install /home/pi/MagicMirror
          > cd vendor && npm install
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          audited 220 packages in 13.98s
          found 5 vulnerabilities (4 low, 1 high)
            run `npm audit fix` to fix them, or `npm audit` for details
          > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
          > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
          MagicMirror installation successful!
          > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
          > cd fonts && npm install
          audited 1 package in 1.385s
          found 0 vulnerabilities
          npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
          updated 1 package and audited 3475 packages in 106.649s
          found 28 vulnerabilities (1 low, 1 moderate, 26 high)
          processing dependency changes for active modules with package.json files
          processing for module MMM-Carousel please wait
          audited 859 packages in 13.644s
          found 2 high severity vulnerabilities
          processing complete for module MMM-Carousel
          processing for module MMM-PublicTransportHafas please wait
          audited 41 packages in 3.408s
          processing complete for module MMM-PublicTransportHafas
          audited 41 packages in 2.67s
          audited 41 packages in 3.904s
          restoring custom.css
          upgrade.log
          Upgrade started - Mi Okt 16 22:11:36 CEST 2019
          user requested to force apply changes
          saving custom.css
          not english or locale not set, set git alias
          remote name = origin
          current branch = master
          Auf Branch master
          Ihr Branch ist auf demselben Stand wie 'origin/master'.
          Zum Commit vorgemerkte Änderungen:
            (benutzen Sie "git reset HEAD <Datei>..." zum Entfernen aus der Staging-Area)
          	gelöscht:       css/custom.css
          Änderungen, die nicht zum Commit vorgemerkt sind:
            (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
            (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
          	geändert:       package-lock.json
          	geändert:       vendor/package-lock.json
          Unversionierte Dateien:
          	%logfile
          	core
          	css/save_custom.css
          	installers/dumpactivemodules.js
          	installers/pm2_MagicMirror_new.json
          	installers/stashed_files
          	installers/upgrade.log.bak2
          	mm.sh
          	nohup.out
             package-lock.json
          save/restore files selection = n
          restoring package-lock.json from repo
          restoring vendor/package-lock.json from repo
          test merge result rc='' , if empty, no conflicts
          executing merge, apply specified
          merge result rc= 0
           Already up to date.
          processor architecture is armv7l
          removing git alias
          Upgrade ended - Mi Okt 16 22:14:11 CEST 2019
          do I need to akt in any way here or other point?
          cheers, bdream
            sdetweil @bdream
            @bdream thank you for your help and patience… all looks great!!
            no, you do not need to do anything about the last two entries.
              bdream
              so we are done and I set post to solved.
              Many thanks for your great help and patience with this newbe-stuff :smiling_face_with_sunglasses:
              cheers, bdream
                sdetweil @bdream
                @bdream said in Update to v2.9.0 fail:
                you are welcome… and why I want to make these scripts solid
                • F Offline
                  fiaskogaul
                  Is the Link dead? I get 404 or when I execute the script “Syntaxfehler beim unerwarteten Wort `newline’”
                    sdetweil @fiaskogaul
                    @fiaskogaul which link?
                    see this topic for the current link for update
                    https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                    • 3 / 3
