    MYMIRROR - From Modena
    28 Posts 6 Posters 24.1k Views 7 Watching
      s.monti.74 @richland007
      @richland007 I can’t upload in the editor the full code because the editor blocks it (probably it converts the “;” char as the end of the code) I also can’t upload a txt file witch the code, i can upload only images
      richland007R Cr4z33C 2 Replies Last reply Reply Quote 0
      • richland007R
        richland007 @s.monti.74
        @s-monti-74 Can you e-mail the Arduino sketch as txt file to me please at grabocka (@) sbcglobal.net
        oh the config.js entries also please so i can change my names into it :)
        Grazie mille
        Denis
        • Cr4z33C
          Cr4z33 @s.monti.74
          @s-monti-74 said in MYMIRROR - From Modena:
          You can easily copy&paste everything to pastebin.com then share here the link for others. ;)
            s.monti.74 @Cr4z33
            @Cr4z33
            this is my “paste”…
            https://pastebin.com/wY8yVtpv
            richland007R 1 Reply Last reply Reply Quote 1
            • richland007R
              @s-monti-74 Thank you i will try to work on it this weekend and if i run into trouble i will bother you again LOL :)
              thanks again
                seychellch
                MMM-NowPlayingOnSpotify
                Well done. Did you have problems installing MMM-NowPlayingOnSpotify? I followed the instructions without problems, but when I tried to invoke Spotify using Google Assistant, I got the message that I need to install my Spotify credentials, which I did during installation. I still cannot figure out the solution. Maybe you can share your experience?
                  s.monti.74 @seychellch
                  @seychellch I use the module only to view what I am listening on Spotify in that moment (singer, song, disco cover). I use Alexa to play songs and the Mirror to view them.
                  • CledidC
                    Cledid
                    It work as I want
