    MYMIRROR - From Modena
    28 Posts 6 Posters 24.1k Views 7 Watching
      sdetweil @richland007
      @richland007 i believe he uses both… usb for sketch and serial for data
        s.monti.74 @richland007
        @richland007 I have modified the code before update it, to make it simpler and probably something is wrong.
        I use 2 tags, the first to recognize me (S) and the second to recognize my wife (G)
        for serial communication, later I send you a photo
          s.monti.74
          richland007R 1 Reply Last reply Reply Quote 0
          • richland007R
            richland007 @s.monti.74
            @s-monti-74 Great i got the schematics now :)
            Can you please post again the complete Arduino code
            Thank you very very much
            Denis
              @richland007 I can’t upload in the editor the full code because the editor blocks it (probably it converts the “;” char as the end of the code) I also can’t upload a txt file witch the code, i can upload only images
              richland007R Cr4z33C 2 Replies Last reply Reply Quote 0
              • richland007R
                @s-monti-74 Can you e-mail the Arduino sketch as txt file to me please at grabocka (@) sbcglobal.net
                oh the config.js entries also please so i can change my names into it :)
                Grazie mille
                Denis
                • Cr4z33C
                  Cr4z33 @s.monti.74
                  @s-monti-74 said in MYMIRROR - From Modena:
                  You can easily copy&paste everything to pastebin.com then share here the link for others. ;)
                    s.monti.74 @Cr4z33
                    @Cr4z33
                    this is my “paste”…
                    https://pastebin.com/wY8yVtpv
                    richland007R 1 Reply Last reply Reply Quote 1
                    • richland007R
                      @s-monti-74 Thank you i will try to work on it this weekend and if i run into trouble i will bother you again LOL :)
                      thanks again
                        seychellch
                        MMM-NowPlayingOnSpotify
                        Well done. Did you have problems installing MMM-NowPlayingOnSpotify? I followed the instructions without problems, but when I tried to invoke Spotify using Google Assistant, I got the message that I need to install my Spotify credentials, which I did during installation. I still cannot figure out the solution. Maybe you can share your experience?
                          s.monti.74 @seychellch
                          @seychellch I use the module only to view what I am listening on Spotify in that moment (singer, song, disco cover). I use Alexa to play songs and the Mirror to view them.
                          • CledidC
                            Cledid
                            It work as I want
