    MMM-Sunrise-Sunset
    44 Posts 9 Posters 28.1k Views 10 Watching
      siggmur
      Thanks for the quick reply, I forgot the quotation marks, but it should throw a config error, not a black screen like I am getting?
        sdetweil @siggmur
        @siggmur black screen usually means missing library file.
        look at the startup.messages
        either
        pm2 logs --lines=100
        or the terminal window where do
        npm start
          siggmur
          @sdetweil ah, now we might be cooking. I find to suspected issues, but I am a bit to noobish to understand:
          [2020-08-01 01:35:48.402] [LOG] No helper found for module: MMM-Sunrise-Sunset.
          and:
          Fontconfig warning: “/etc/fonts/fonts.conf”, line 100: unknown element “blank”
          [2020-08-01 01:35:50.724] [ERROR] Whoops! There was an uncaught exception…
          [2020-08-01 01:35:50.727] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
          at Server.setupListenHandle [as _listen2] (net.js:1226:14)
          at listenInCluster (net.js:1274:12)
          at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
          code: ‘EADDRINUSE’,
          errno: ‘EADDRINUSE’,
          syscall: ‘listen’,
          address: ‘127.0.0.1’,
          port: 8080
          Any idea what it could be?
            sdetweil @siggmur
            @siggmur eaddr in use means something is still using that port 8080,
            pm2’s job is to start at boot, so you can have more than one running
            keep stopping
            check w
            ps -ef | grep node |grep -v grep
            kill things til u get none.
            then
            cd ~/MagicMirror
            npm start
            • 3 / 3
