    GActions CLI Login Issue
    google apigoogle assistantgactionsactionsgoogleassistantlogging
    4 Posts 2 Posters 1.4k Views 2 Watching
    • Lorenzo_ZappaL Offline
      Lorenzo_Zappa
      I had recently tried the Google Assistant SDK (https://developers.google.com/assistant … ice/python) on my raspberry pi, but when I tried to add my custom actions It prompted my to download the gaction packet (https://developers.google.com/assistant … ctions-cli) and, in order to make it work, I now have to login:
      ./gactions login
      Visit the URL to authorize access:
      https://accounts.google.com/o/oauth2/v2/auth?(more and more...)
      If I try to visit this address and I try to login with the account I created the project with:
      https://i.stack.imgur.com/hw0bY.png
      I get this error massage:
      https://i.stack.imgur.com/QjjAz.png
      Any idea how to fix this problem?
      In addition to this whenever I try the default command “Turn On” the assistant answers:
      “sorry, power control is not yet supported”
      How can I fix this?
      Thank you
      • ? Offline
        A Former User @Lorenzo_Zappa
        @Lorenzo_Zappa
        for last question, unless overriding custom device traits, SDK (for device) itself don’t know how to treat it.
        Lorenzo_ZappaL 1 Reply Last reply Reply Quote 0
          Lorenzo_Zappa @Guest
          @Sean if I override it, do I have to push it as a custom trail and therefore use gaction CLI?
          • ? Offline
            @Lorenzo_Zappa
            I think that is another issue with your prior login issue.
            For login issue;
            I’m using gactions cli also to provide custom action to my MMM-AssistantMk2
            https://developers.google.com/assistant/tools/gactions-cli
            my steps are here; https://github.com/eouia/MMM-AssistantMk2/wiki/gAction
            Those are all I have to do.
            For traits issue;
            You have to add trait to your project. (It is called as custom trait but I think pre-defined trait makes a sense better)
            https://developers.google.com/assistant/sdk/guides/service/python/extend/register-device-traits
            Then response of Assistant will have some additional action field like “action.devices.commands.OnOff” when you say something like “turn on”. Before the registration, Assistant will response like “I can’t do” but after, response will be something defined in your action package.
            Then, you can do your job when that action is comming as a response.
