    MMM-MyCommute not showing up.
    31 Posts 4 Posters 12.6k Views 4 Watching
      Doogain
      So I added this to config.js in MagicMirror/config
      module: “MMM-MyCommute”,
      position: “top_left”,
      header: “Traffic”,
      classes: “default everyone”,
      I recieved this error in developer console now
      alt text
      • buzzkcB Offline
        buzzkc
        @Doogain
        Your config entry should look more like the one in the Readme.md page of the module (https://github.com/jclarke0000/MMM-MyCommute)
        Also, be sure you followed all of the installation notes in the readme.
          module: 'MMM-MyCommute',
          position: 'top_left',
            apikey: 'API_KEY_FROM_GOOGLE',
            origin: '65 Front St W, Toronto, ON M5J 1E6',
            startTime: '00:00',
            endTime: '23:59',
            hideDays: [0,6],
            destinations: [
                destination: '14 Duncan St Toronto, ON M5H 3G8',
                label: 'Air Canada Centre',
                mode: 'walking',
                color: '#82E5AA'
                destination: '317 Dundas St W, Toronto, ON M5T 1G4',
                label: 'Art Gallery of Ontario',
                mode: 'transit'
                destination: '55 Mill St, Toronto, ON M5A 3C4',
                label: 'Distillery District',
                mode: 'bicycling'
                destination: '6301 Silver Dart Dr, Mississauga, ON L5P 1B2',
                label: 'Pearson Airport',
                avoid: 'tolls'
        Darren
        My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
          sdetweil @Doogain
          @Doogain u modified the module source. Please remove yours, and customize the config.js
            Doogain
            I reverted the module source, I messed up bigtime on that. The modules show up in MM now, and that is so great! Thanks a lot!
            It does give a me a error instead of commute time tho, I think thats a either a API or adress error.
            Which API do I have to select from google? It gives me several choices.
            • buzzkcB Offline
              buzzkc
              I believe it’s the Maps Javascript API>>Directions API
              Darren
                Doogain @buzzkc
                @buzzkc said in MMM-MyCommute not showing up.:
                Hmm still getting a error where it should say commute time.
                It says:
                MMM-MyCommute: You must enable Billing on the Google Cloud Project at https://console.cloud.google.com/project/_/billing/enable Learn more at https://developers.google.com/maps/gmp-get-started
                I already have that enabled tho.
                  Doogain
                  I figured it out. I had to enable all the following
                  1.) Maps Javascript API
                  2.) Directions API
                  3.) Geocoding API.
                  Marking as solved, thanks for all the help :-)
                    sdetweil @Doogain
                    This post is deleted!
                      spoonek
                      Sorry to bump an old post, seemed like a better idea vs creating a new one…
                      I’m having the same issue. I’m using MagicMirror 2.12. The MMM-MyCommute module shows “Error” in red for my destination. I have an api key. The api key is active. I’ve added the Directions API, Geocoding API and Maps JavaScript API to my Google Cloud Platform account. I’ve tried both apikey and apiKey. I did read on the Google site that the request needs to be something like “key_api” but can’t find that verbiage again to validate. Not sure what else I can do at this point. Any tips? Many thanks!!
                      code:
                      	header: 'Commute Times',
                      		apiKey: '**********************************',
                      		origin: '**my home address**',
                      		startTime: '00:00',
                      		endTime: '23:59',
                      		destinations: [
                      				destination: '6000 N Terminal Pkwy, Atlanta, GA 30320',
                      				label: 'Airport'
                        sdetweil @spoonek
                        @spoonek apikey, all lower case, read the module doc
                        open the developers window ctrl-shift-i, then select the console tab and scroll up see any errors. u can also filter messages by module, by placing part of the module name in the filter field ‘comm’ for example
                        • 3 / 4
