    Need help for PIR-SENSOR
    4 Posts 2 Posters 1.3k Views 2 Watching
    • C Offline
      cyberjarou
      Hello everyone, I need help for PIR-SENSOR, I have followed all the steps to make the sensor work on the raspberry but I have the impression that it doesn’t work on the gpio port.
      If someone could help me solve the problem, it would be nice.
      I am French and I speak English with the translator so if you don’t understand things tell me.
      I’d give you more information but I’d like to make sure first that someone will answer me.
      I’m a beginner in programming so if you could simplify things a little bit.
      FoziF 1 Reply Last reply Reply Quote 0
      • C Offline
        cyberjarou
        language: "fr",
        timeFormat: 24,
        units: "metric",
        		module: "alert",
        		module: "updatenotification",
        		position: "top_bar"
        		module: "clock",
        		position: "top_left"
        		module: "compliments",
        		position: "lower_third"
        		module: "currentweather",
        			locationID: "3018692",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
        			appid: "3d1a7886937461a9c659f9f2984fac88"
        		module: "weatherforecast",
        		header: " ",
        			locationID: "3018692",  //ID from https://openweathermap.org/city
        		module: "newsfeed",
        		position: "bottom_bar",
        			feeds: [
        					title: "Le Monde",
        					url: "http://www.lemonde.fr/rss/une.xml"
        			showSourceTitle: true,
        			showPublishDate: true
        	        module: "MMM-Screencast",
        	        position: "center", // This position is for a hidden <div /> and not the screencast window
        		        position: "center",
        		        height: 300,
        		        width: 500,
        	        module : "MMM-PIR-Sensor",
        	        config : {
                                     sensorPIN: 4,
                                     powerSaving: true
                            module: "MMM-LocalTemperature",
                            position: "top_left", // Only add a position if you want this module to display the data
                            header: "temperature de la maison",
                                    sensorPin: 21, // For GPIO 22
        I tried everything I don’t understand I still have wring-pi
        put the code request in the config.js and in the command prompt
        -Navigate into your MagicMirror’s modules folder and execute git clone https://github.com/paviro/MMM-PIR-Sensor.git. A new folder will appear navigate into it.
        -Execute npm install to install the node dependencies.
        -Add your user (pi?) to the gpio group by executing sudo usermod -a -G gpio pi.
        -Execute sudo chmod u+s /opt/vc/bin/tvservice && sudo chmod u+s /bin/chvt to allow turning on/off the hdmi output.
        -Reboot your Pi.
        • FoziF Offline
          Fozi Project Sponsor @cyberjarou
          @cyberjarou
          Try to add the delay time when the monitor should turn off, e.g. after 60 seconds.
          Like this:
          	module: 'MMM-PIR-Sensor',
          	powerSavingDelay: 60, // (seconds) how long the monitor will be turned on
          After 60 seconds the monitor will turn off and turn on after the sensor detect motion.
          • C Offline
            cyberjarou @Fozi
            @Fozi
            module : “MMM-PIR-Sensor”,
            config : {
            sensorPIN: 4,
            powerSaving: true
            thank you for your answer but it doesn’t work at all, the mirror doesn’t configure as before, i.e. it doesn’t mark the required info anymore, it requests me to create a config file and can’t stop where I put the brace
