    News feed not working
    5 Posts 3 Posters 3.3k Views 3 Watching
    • A
      albaace
      Hello,
      I changed the web page from the news feed to a catalan newspaper (www.ara.cat) and it is not working. I changed the url from the config.js file and from the file of the module. When running Magic Mirror 2 all the modules I configurated work except the news one. It says that it is loading and doesn’t show any news.
      I’d be glad if you could help me.
      • yawnsY
        yawns Moderator
        Did you reboot your pi or the magicmirror process after changing your config?
        If so, could you post the part of your config file with the news section?
        • W
          Wedee
          You need to use the RSS feed address.
          Goto - http://www.ara.cat/rss.html and choose the topic you are interested in showing.
          You should end up with an address like…
          http://www.ara.cat/rss/politica/
          • A
            albaace
            Thank you very much @Wedee @yawns
            How can I use the RSS adress of the home page?
            • A
              albaace
              I got it!
              But still says it is charging. How can I make so that the news don’t get translated??
