    MMM-DumpsterDay
    83 Posts 11 Posters 65.6k Views 12 Watching
      BD0G
      I set up my config.js to todays date (for testing) so that I could see the trash can icons show up. The format that one needs to use is Day.Month.Year on the
      basicStartDate:
      plasticStartDate:
      landscapeStartDate:
      lines
      Here is my config.js which does display the cans as it should.
      	module:"MMM-DumpsterDay",
      	position:"bottom_bar",
      		refreshInterval: 18000000, // Default: 18000000 = 5 hours
      		pulse: true, 			   // Default: true - Makes the module pulsating
      		enableBasic: true, 				// Enable basic trashcan
      		basicStartDate: "11.11.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
      		basicDateDiff_1: 7,			// Trashday reoccurance - Default: 14 (every 14 days)
      		basicNotifyDayBefore: true,		//Default: true - If you want the notification to appear also the day before the dumpster day
      		enablePlastic: false,			// Same values as basic but for Plastic
      		plasticStartDate: "11.11.2019",
      		plasticDateDiff_1: 28,
      		plasticNotifyDayBefore: true,
      		enableLandscape: true,			// Same values as basic but for Landscape
      		landscapeStartDate: "11.11.2019",
      		landscapeDateDiff_1: 14,
      		landscapeNotifyDayBefore: true,
      When I change the dates to the 13th of this month then the trash cans are not shown as they should not be shown until the day BEFORE trash day and the DAY of trash day. Which would be tomorrow and the day after.
        mrdenmark @BD0G
        @BD0G
        and you leave enableplastic set to false?and it still shows up on the weeks it should?
          mrdenmark
          if i use this config all bins show-
          	position:"top_left",
          		pulse: false, 			   // Default: true - Makes the module pulsating
          		basicStartDate: "12.11.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
          		basicDateDiff_2: 7,			// Trashday reoccurance - Default: 14 (every 14 days)
          		enablePlastic: true,			// Same values as basic but for Plastic
          		plasticStartDate: "12.11.2019",
          		plasticDateDiff_2: 14,
          		landscapeStartDate: "12.11.2019",
          		landscapeDateDiff_2: 14,
          if i use this then 2 bins show-
          but if i change it to either of these then only the basic shows up -
          		plasticStartDate: "18.11.2019",
          or
          		plasticStartDate: "18.11.2019",code_text
          maybe i’m misunderstanding but it seems the second last one is the one i require.
          for reference my red get picked up every monday and the other 2 alternate every 2 weeks,again on monday
          M D 2 Replies Last reply Reply Quote 0
            mrdenmark @mrdenmark
            @mrdenmark apologies foe formatting above!
              DeanoNoire @mrdenmark
              @mrdenmark if you set the date to 18.11.2019 and the occurance is every 14 days then it’s correct :)
              If the enable value is true - the image is not visible as it’s not a trashcan day.
              If the enable value is false - the part of the module is disabled and is not evaluated at all. Also I recommend to use start dates from the past, not future :)
                BD0G
                Since the Red Can graphic was added to the github repository my MagicMirror update-notification module indicates an update is needed to the MMM-DumpsterDay module. This made me think that it would be good to add the update process to the github repository instructions.
                I just did a
                git fetch and then a
                git pull
                from within the MagicMirror/modules/MMM-DumpsterDay sub directory and that updated the module.
                  Doughboy99 @BD0G
                  Re: MMM-DumpsterDay
                  I am having problems getting the bins to show correctly. I have three different bin collections
                  Rubbish(basic) collected fortnightly on thursdays next collection due 21st November
                  Recycling(plastic) collected fortnightly on thursdays next collection due 14th November
                  Composting(landscape) collected fortnightly on Mondays next collection due 25th November
                  The icon for the plastic collection is displayed as expected but the landscaping icon is also showing today(14th) even though it is not due until the 25th. Any ideas what the issue is?
                  This is the config file I am using
                  {module:“MMM-DumpsterDay”,
                  position:“lower_third”,
                  			basicStartDate: "24.10.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                  			basicDateDiff_1: 14,			// Trashday reoccurance - Default: 14 (every 14 days)
                  			plasticStartDate: "31.10.2019",
                  			plasticDateDiff_1: 14,
                  			landscapeStartDate: "14.10.2019",
                    sdetweil @mrdenmark
                    @mrdenmark said in MMM-DumpsterDay:
                    fixed…
                    the three tildes need to be on a separate line by themselves
                      Doughboy99 @Doughboy99
                      @Doughboy99
                      I think I have found the issue for me.
                      in MMM-DumpsterDay.js the if statement
                      	if (enableLandscape == true){
                      	landscapeTrashDayResult = this.isPlasticTrashDay();
                      	Log.info("landscapeTrashDayResult: "+landscapeTrashDayResult);
                      	var landscapeDiv = document.createElement("div");
                      	landscapeDiv.className = "landscapeDiv";
                      	wrapper.appendChild(landscapeDiv);
                      		if (landscapeTrashDayResult == 0){
                      		landscapeDiv.classList.add("non_today")
                      line 83 should read
                      landscapeTrashDayResult = this.isLandscapeTrashDay();
                      This seems to fix my issue.
                        BD0G @Doughboy99
                        @Doughboy99
                        Good catch. Seems logical that the statement should pertain to Landscape because of what precedes it.
                        I made the change to my MMM-DumpsterDay.js . You can report the issue via github and the author @DeanoNoire can add the changes.
                        Here is the link to report github MMM-DumpsterDay Issues
                          Doughboy99 @BD0G
                          @BD0G Thanks Ive posted an issue. Your link is to another reposirory for a similar module .
                          The correct link is here
                          B D 2 Replies Last reply Reply Quote 1
                            BD0G @Doughboy99
                            @Doughboy99 Corrected the link. Thanks!
                              DeanoNoire @Doughboy99
                              @Doughboy99 Thanks a lot guys, I just corrected it on github.
                              Have a good one!
                                BD0G
                                Thanks @DeanoNoire . Any plans to implement the “Tomorrow is Trash Day” and “Today is Trash Day” text?
                                  DeanoNoire @BD0G
                                  @BD0G wasn’t really planning to, but I guess I can add it as an option :) will see how much work is wating for me at job this week :D
                                  • P Offline
                                    Paddi
                                    @DeanoNoire Had no luck to make it work. When adding in the config.js and restarting mirror it messes up things. Black background instead of usual picture. Some modules do not load…
                                    Could you help ?
                                      BD0G @Paddi
                                      @Paddi Try Pressing the CTRL-Shift-i keys together once the Magic Mirror has loaded to bring up the developers window. Then click on the tab labeled console and look for any errors. Usually in Red text. When there is a black screen it “typically” indicates one or more of the modules has crashed.
                                        BD0G
                                        I had this module working great , but for some strange reason it no longer shows the Landscape can. I set the dates to tommorrow which is trash day so the Trash Can and Landscape can should be displayed the day before (which it today) and only the Trash Can is displayed. My date is set correctly on the Magic Mirror so its not that.
                                        Here is my config entry
                                        		basicStartDate: "27.11.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                                        		plasticStartDate: "27.11.2019",
                                        		landscapeStartDate: "27.11.2019",
                                          DeanoNoire @BD0G
                                          @BD0G Can you try updating the latest version of this module from github? :) there was an issue with Landscape part.
                                            mrdenmark
                                            has anyone managed to get this module to work correctly?i’ve tried allsorts of config options but it behaves quite strangely.
                                            my collection day is monday,the red gets collected every monday and the blue and yellow get alternate and get collected biweekly.
                                            the module did as it should the first week and never since then,it only shows 1 bin,some weeks it shows a bin to be collected on thursday,dissapears on friday and re-appears on sunday!
                                                    position:"upper_third",
                                                            pulse: false,
                                                            maxWidth: "75px",                          // Default: true - Makes the module pulsating
                                                            basicNotifyDayBefore: true,             //Default: true - If you want the notification to appear also t$
                                                            plasticStartDate: "04.11.2019",
                                            • 3 / 5
